replace just front air bag?
Old 06-07-2016, 02:45 PM
1xsculler's Avatar
gl 450
How difficult is it to replace just the air bag on a front strut?
Old 06-07-2016, 07:13 PM
2010GL550's Avatar
GL550
2 hours or so. But do yourself a favor, replace the whole strut assembly. it's easier and if purchased from Arnott will have a lifetime warranty.
Old 06-07-2016, 11:00 PM
BlownV8's Avatar
Received 1,003 Likes on 810 Posts
E55, GLS450, GL63, GLE350
You might as well do both sides. The other one will not be far behind if it hasn't already been replaced.
Old 06-12-2016, 10:54 PM
Captincvmn's Avatar
Land Rover Discovery series I
RMT
Give 'um a shot
http://www.rebuildmastertech.com/mercedes-benz/gl-class/gl-class-air-suspension-parts/gl-class-2007-2012-x164-non-ads-airmatic/
Old 06-15-2016, 02:59 PM
thedad's Avatar
1965 220B, 2011 GL450
It depends.. corrosion can make this job a real pain. If the fasteners arent corroded badly its not a bad job. Two hours is really unrealistic unless youve done it before and there is no rust or grease everywhere. You really need to do them in pairs as the other wont be far behind and the rear ones will be going shortly as well. I did both fronts on my 11 GL450 along with new pads and rotors and it took me about 6 hours taking my time. I replaced just the air bags as the struts themselves were still fine. Ended up having to do the rears 4 months later....The factory bags are junk, If Toyota had come out with parts this failure prone there would have been a recall. These trucks and thats what they are can be dangerous to drive with deflated bags. If you drive your vehicle with bad air bags you will burn up the air pump which is really pricey. Good luck
Quick Reply: replace just front air bag?
