Roof bike rack OEM
Roof bike rack OEM
Does anyone know how many bikes I can fit on the top of the GL? Ours doesn't have a tow hitch so I need to put everything on the roof. I think my parents used to put 4 on the roof of their Benzes when I was a kid. I would use the OEM kit.
Frankly - if you just need a trailer hitch for rear mounted bike rack - then Curt has a hitch for about $350 and without needing/connecting electrical mounting at a trailer hitch guy will be about $100-$125 - heck a U-Haul hitch place might do the whole deal under $500.
You can go to the Curt web site - see the model hitch that will fit - and they should have video install instructions - not to make it DIY necessarily - but from a physical/mechanical standpoint the hitch is not a big deal.
It's when you add electrical for trailer lights/brakes - and/or integrating the trailer hitch features in the GL - it's that electrical/labor/connectivity that gets pircey.
With a hitch - then you have your choice of rear rack's - which for most makes more sense than roof mounted.
For roof mount - 1st you need to add cross-bars - which can be OE or several Thule/Whisper/etc can fit.
Then with the cross bars - you choose the bike mounting you to fit to the cross bars - bike mount is up to you.
I can get the Mercedes parts at cost...but it is the labor I am worried about. That's why I was thinking the roof might work. I don't think we will ever tow anything...so I am not too worried about the extra parts of the trailer hitch. I do wish mine had had it though. Oh well!
I thought I saw on here that the curt one can't be installed bc of the single exhaust or something? Or did I read that incorrectly?
once you add the crossbars and then the bike rack on top of those, it will be a royal pain to get the bikes on and off the rack - because of the height.
I think the simple hitch mentioned above is a better solution, especially if you plan to carry multiple bikes. With a roof rack you'd need a step ladder to load a bike anywhere but the very edge of the roof.
2023 EQB 350 & 2014 GL350
And then just slightly drop one bike once and compare the repair costs of the GL to the price of the hitch. I also witnessed my neighbor attempt to drive his car to his garage with a roof mounted bike on top.
Just call me skittish about roof mounted bikes.
FWIW, we have the Yakima Fullswing and would easily recommended it as a hitch mounted rack. Even with a full load of bikes it can swing clear and permit access to the rear hatch of the GL.
Frankly - with regards to adding the rear hitch for bike rack use - focus on aftermarket - and Curt is a top maker there - absolutely no reason to obsess about MB/OE hitch.
If you are not prepared to do DIY - do NOT waste money on MB dealer install - you can have a local trailer hitch expert - many larger U-Haul stores for example - as this is not rocket science to them since you are not asking for wiring/electrical hookup.
Keep the beat !
Keep the beat !
Keep the beat !
Keep the beat !
