why has MB cut down the GLEd from the ML350?
2023 EQS 450 4MATIC SUV
I would like to understand why the GLEd 300 been reduced from the ML350. I have had my ML350 Bluetech for a little over 2 years and have been very happy with it. But now MB seems to think that a good V6 is too good for us that like the GLE (ML) body style and we should have the engine reduced by ~20% power and torque (HP down to 201 from 255 and torgue down 369 from 455) and a 4 cylinder to boot. Some have said it is a requirement for fuel economy. If that is the case why are the same or bigger engines available for the gas models (they have the same or bigger). I just don't understand why a good vehicle like the ML350 Bluetech is being taken down a notch because you change the name.
I don't want a GLEd, I don't need a GLSd. What else is there that gives good power, good fuel economy and can haul over 7,000 pounds (if I want; I haven't hauled anything so far). I guess I may need to look outside of MB?
Move to Canada where Mercedes is smart enough to realize customers still want a six cylinder diesel. Loving my new one and the fuel economy with the new 9 speed is insane. I notice the transmission rarely uses 8th and 9th gear unless over the speed limit on the highway. Can't wait to drive this thing down to my vacation home in Florida and see what it can do on a real road trip.
I own a 2015 ML250 and have now driven it over 11,000 miles. It performs very well and is very comparable to other Mercedes I now own and have owned in the past. The smaller 4cyl. performs very well in town and on the highway. it has noticeably less turbo lag, does get better mileage, and retains substantial towing capacity.
It is a fact of life that all manufacturers have to increase mileage and smaller displacement engines are the path to that goal. Substantial changes have been made throughout the line even to the point where a 4cyl. will be standard on the new E Class.
Thanks, maybe Canada is an answer. It is just irritating that Luxury performance is going down unless you almost double for an AMG.
Also, the engines available for gas models provide an option of a smaller engine but still provides the same they have for years. I would not be saying anything if they offered the same engine as before and gave the option of a smaller one; but they are not giving any option.
I'm glad you are happy with your vehicle but that's wasn't the issue. The same engine is available in the GLS so why is it not available as an option for the GLEd; as it seems it is in Canada. Diesels do better than gas in emissions and mileage so why take away the option and give 500 LBS less towing capability.
Thanks for your input but it doesn't sound like you have compared the ML350 Bluetech to the GLEd.
I am familiar with both diesels. Without a doubt the 350 has more power and will tow more. It also suffers from a certain amount of turbo lag and definitely gets poorer fuel milage, a primary reason to buy diesel. In my opinion, the 4 cyl. is more drivable on a daily basis unless you are buying it to tow with daily. There is a new 4cyl. diesel on the way that out performs both the 6cyl. and the 4cyl. both in power and mileage. Maybe the solution is to wait.
There's a couple of things at play here. First, we can't compare the vehicle lineup here with what is available in any other country, including Canada. MBUSA make the decisions on what to offer in the US market. EPA testing and costly US FMVSS have to be met for each engine/transmission/seat configuration combination for each vehicle. However it was done (focus groups, customer surveys, etc), MBUSA saw that there was a greater customer base interested in the diesel ML/GLE for the fuel economy rather than the number of customers who want the diesel for the torque and towing capacity. Second consideration are the ever tightening CAFE standards being enforced upon each manufacturer. Offer up the ML350 BTC as a sacrificial lamb if you will, boost your EPA numbers by swapping in the 4 cylinder diesel, and now you have more room for vehicles like the GLE63, GLS63, etc. The gas models have seen this same transition as well. The GL450 used to be a V8, now it's a 6. The ML550 V8 is gone and now there's the 6 cylinder ML/GLE400.
I'm in the same boat as you. I had a ML350 BTC and loved it. We hated the ML250 BTC/GLE300d. Thing is though, if you had not owned or drove the 350 before, walking fresh into 300d you would think it is perfectly fine. Our 3 finalist for replacing the 350 was the X5 35d, GL350 BTC, or GLE350 (gas). We decided to give the latter a try.
Interesting tidbit though, MBUSA did get EPA approval for a GLE350d. 6 cylinder diesel w/ the 9 speed transmission. There's been no word whatsoever on that vehicle. I'm curious of all the money spent on EPA testing. Fingers crossed.
