2010 GLK350 Front Grill Chip
Old 07-30-2014, 11:55 PM
apr0607's Avatar
GLK350
Hi Everyone,
My front grill had an unfortunate mishap on the highway - a piece of debris flew up and chipped/damaged the front grill - fortunately this was the only damage, it could have been much worse!
I'm trying to figure out my options - the dealership said the ENTIRE grill needs to be replaced at a cost of $800+
Insurance will cover as a comprehensive claim but the deductible is $500.
Is there anyway I can just buy the strip that is damaged and replace that or do I need to replace the whole grill? Or is it possible to make some kind of patch-job and then disguise it by plasti-dipping the grill black so that it is camouflaged?
Thank you in advance!
Old 07-31-2014, 08:55 AM
bop11's Avatar
350 GLK, C280
If it is just that strip, you could remove the grill,and use some epoxy (Bondo) with a light filler and fill in the area. To avoid a heavy blob, you can tape card board behind to keep the repair area thin. Make sure you clean the area with acetone or MEK to insure a good bond. A quick sanding and some spray paint and no one would know. If "YOU" would know, then this would be a good time to paint the bars flat black as many others have done. This would mean that you didn't need to match the paint.
Old 07-31-2014, 05:38 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Looks like going price is $500.- $650.00 http://www.mbpartsworld.com/showAsse...hString=grille
Old 07-31-2014, 05:42 PM
Also there is one damaged but with good pieces that you need on the bay for a price of $90. The question is how difficult will it be to take one apart without breaking more pieces!
Old 08-02-2014, 12:59 AM
apr0607's Avatar
GLK350
Thank you for the very helpful hints and tips. I will definitely try the first option of repair and then look into fully replacing if I can't get that to work. Unfortunately I have zero experience doing anything like this, but will give it my best shot.
Thank you again for the help and suggestions, it is very much appreciated.
Quick Reply: 2010 GLK350 Front Grill Chip
