2015 GLK Questions about mats
Old 08-27-2014, 03:21 AM
plainzwalker's Avatar
2015 GLK 250
Good morning/afternoon,
We just picked up our 2015 GLK 250 from the factory yesterday in Sindelfingen. We are looking at getting all weather floor mats and trunk liner, however the problem is no-one is listing them besides MB and they are hard plastic and not rubber. Does anyone know if they mats/cargo mat are the same dimensions from 2014 to 2015?
Thank you
Old 08-27-2014, 06:55 AM
N91K's Avatar
GLK350, G55, AMG GTS, C63 507
I would suppose facelift models would have the same dimensions, but i might be wrong.
Old 08-27-2014, 08:39 AM
Rdub's Avatar
14 GLK 250 BT
Unless there is a redesign from 2014, it should be exactly the same GLK 350/250 BT. So to widen your search you can GOOGLE the GLK 350. You can also search weather tech that has both conventional rubber mats and makes laser cut rubber/plastic floor trays for both front and rear and cargo mats and trays. I have the oem rubber mats that I got from Amazon.
Old 08-28-2014, 04:51 AM
2015 GLK 250
Yeah I called weather tech and they have only started production on C class and one other model for the 2015s and said it would be a couple months before they might start production. I didn't want the actual trays, and was just looking for the heavy duty rubber mats. I would order the 2014's if I knew they would fit, but since I am overseas they would be expensive to have to mail back if they were the wrong size.
Old 08-28-2014, 06:12 AM
N91K's Avatar
From wikipedia: http://en.wikipedia.org/wiki/Mercedes-Benz_GLK-Class
Dimensions
Wheelbase 108.5 in (2,756 mm)
Length 2009–2011: 178.2 in (4,526 mm)
2012–Present: 178.3 in (4,529 mm)
Width 2009–2011: 72.4 in (1,839 mm)
2012–Present: 74.3 in (1,887 mm)
Height 66.9 in (1,699 mm)
Old 08-28-2014, 10:34 AM
Rdub's Avatar
14 GLK 250 BT
From the lack of information, being "overseas" can be a further disconnect. Some stuff (what it will be in the future is anyones guess) available there would not be available "HERE" and vice versa. So I only answered on the unsaid assumption you are coming back state side.
Old 08-28-2014, 08:17 PM
pawzitiv's Avatar
2011 W463.237; 1991 W461.401
The Husky Liners WeatherBeater #98821 set fits my 2015 GLK350 4Matic perfectly even though they are stated to fit MY 2010 to 2014. Also, the made-to-order cargo liner from Canvasback is, again, a perfect fit.
http://stores.canvasback.com/servlet/Detail?category=Mercedes+Liners&no=285¶m_referer=h ttp%3A%2F%2Fstores.canvasback.com%2Fservlet%2FCate gories%3Fcategory%3DMercedes%2BLiners&searchpath=3 941118
Hope this helps ...
Old 08-31-2014, 12:00 PM
moda_way's Avatar
GLK 350
I ordered weathertechs for my MY 2015 and the only thing I noticed was they don't have the button attachments for the passenger side. I'm not sure if the MY2014 had these buttons, but the weathertechs fit fine right on top of the stock buttons.
Old 09-02-2014, 08:21 AM
RSNovi's Avatar
2014 Mercedes GLK 250 - Polar White
I went with the Husky Liners on my 2014 GLK250. The main reason I went with them is that they cover the area where you rest your left foot. The dealer all weather floor mats did not cover that area. I am quite happy with the Husky Liners.
Old 09-04-2014, 10:59 AM
2015 GLK 250
Hope this helps ...
Exactly what was looking for thank you very much! On the Husky Liners, is the rear a 2 piece or 1 piece liner? I remember seeing somewhere that even though the picture showed it was a 1 piece but there was a disclaimer saying it was 2 separate pieces
Old 09-04-2014, 10:28 PM
pawzitiv's Avatar
Yes, the Husky Liners for the rear are 2 separate pieces.
Old 09-04-2014, 10:41 PM
sethro1980's Avatar
2013 GLK 350 4Matic
I'd like to see a floor mat that has holes for the rings in the floor. I use a cargo net and would like to be able to have it on top of a mat.
Old 11-18-2014, 01:34 PM
bberge9's Avatar
2015 GLK 250 AMG in Polar White
Go OEM
I just picked up the front and rear floor mats from the dealer I thought they're very reasonably priced and they fit great instructions say that you should remove the carpeting and then place the floor mats down which I did. I also got a sunshade for the front window the quality on that it's not as good as the last one I had. I should also note that I bought the liner from the dealer for the rear trunk area and that seems to be a good fit. Again all made for Mercedes by Mercedes and I'm very pleased with her altogether I think I spent about $330
Quick Reply: 2015 GLK Questions about mats
