What is a B5 service?
Old 11-09-2016, 09:24 AM
grane's Avatar
G350 Bluetec
The display on my wife's car (late production 2013 350 GLK 4x4) with 35k Miles just came up with "B5 service within 30 days."
She basically has a 2014 model as far as the engine and transmission goes. I changed the single engine air filter myself this past summer.
I looked at the updated MB Maintenance Manual online and it does not have this service.
1. Can anyone explain this "B5 service" to me? What is performed and how expensive is it?
2. Since she has not had the 4yr 40k miles transmission service is this a good time to do it? Can we wait to this spring when she will have the 40k miles?
BTW The Dealer service writer keeps telling me that the transmission service is at 70k Miles.
Old 11-09-2016, 12:30 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
http://www.benzshops.com/mercedes-service-b
Old 11-09-2016, 12:56 PM
grane's Avatar
G350 Bluetec
Already know this
Originally Posted by Plutoe
I was unclear in my statement and questions - I know what a B service is. Thanks for the reply but the operative term here is not just B but B5.
What does the "5" mean?
Old 11-09-2016, 03:43 PM
grane's Avatar
G350 Bluetec
I just called a random dealer. They said it would cost $650 and include the items that Plutoe stated.
I asked what the "5" meant and she said "That is for the technician." I could not get her to tell me what it was.
Mystery continues.
Old 11-11-2016, 10:30 PM
autoworrks320's Avatar
93 500e. 15 GLK 250
B5
Its a Mercedes code to tell the dealer know you do some of your own service!
Old 11-12-2016, 08:34 AM
spyked's Avatar
2013 W204, 2015 X204
The transmission service is 70k miles on a 2013 if you have the M276 engine and 7G Tronic Plus. If you are in the U.S. and have a 2013-2015 GLK 350, that is the case for you.
Old 11-13-2016, 10:59 AM
grane's Avatar
G350 Bluetec
Service interval for xmission the ROA? Glynn help!
What is the service interval in the rest of the world for that transmission?
(I refused to be a victim of NA intervals - or lack of same - with our 5 speed transmissions.)
Old 11-13-2016, 11:03 AM
grane's Avatar
G350 Bluetec
Thank you!
Is this true or are you kidding?
How would the car know an authorized service shop (or an individual) changed the oil and filter and the engine air cleaner outside of the FSS intervals?
Old 11-13-2016, 11:48 AM
spyked's Avatar
Look it up somewhere.
I only know about service intervals for engine/trans combos sold in the U.S. In the U.S., the old 7G Tronic was 39k intervals, the updated 7G Plus has totally different fluid and new internals, hence the longer time between service.
Of course, it can't hurt to get it serviced sooner if you want. Just make sure an MB specialist or dealer does it, because it seriously MUST have the correct fluid.
Old 11-14-2016, 10:36 AM
grane's Avatar
G350 Bluetec
Thank you - further question
Thanks. Is the correct transmission fluid one that meets MB spec xxx.14?
Old 11-20-2016, 04:51 PM
Toppthat's Avatar
2014 glk250
Fluid 14 glk with upgraded oil pan and tube
It was at the dealer getting a torque converter drain plug ID parts didn't include with the trans service kit that I found out about the service bulletin,for the deeper pan and overflow tube here the fluid ID parts sent me
Old 11-20-2016, 05:05 PM
grane's Avatar
G350 Bluetec
Service Bulletin?
Is there an MB service bulletin, or whatever they call it now, implying that a deeper pan and overflow tube is required for the 7GT+ transmission? Is this is what the 5 means, and bulletin-required update would be performed at the B service?
I don't quite follow you, sorry it's been a long day. Please explain.
Old 11-20-2016, 06:15 PM
Toppthat's Avatar
2014 glk250
Oil pan
I don't know what that means. Before we took a vacation that included driving 5000 miles in the GLk which was at 20,000 miles I decided to get the trains oil changed ID parts.had The transmission service kit oil pan bolts and the oil but looking into it I found you needed to drain the torque converter and on the Mercedes do not reuse bolts or plugs once so I went to the dealer and while I was there getting a five dollar part I was told that there was a service bulletin for my 2014 GLk250 for deeper oil pan and overflow tube just lucky I guess I got all the parts together and took it to a place that does nothing but Mercedes and described in detail how they change it and it coincided with what my research found. I'm at 28k I've changed engine air 2x. The fuel once. I confess I do have a lift which almost makes it fun.
grane (11-21-2016)
