ML350
ML350
Just bought a 2003 ML350 which has a couple of faults.
The radio plays AM, Weather and CDs just fine but FM is silent or extremely quiet. I found a YouTube video that might help but I'm hoping there's an easier fix or at least a way to diagnose whether it is indeed a faulty occ8001-02 chip (see link below).
Secondly, the rear passenger doors will not open from the outside with either the electronic key or internally via the central locking. You have to physically reach round and pull the door release lever from the inside, so it's not child locks, but perhaps an over zealous anti-theft feature? I doubt whether both actuators have failed.
If anyone has experienced and found fixes for these problems, I'd appreciate the advice.
Last edited by Darren Adkins; 04-27-2016 at 12:45 PM. Reason: Found more useful help.
Darren Adkins (04-27-2016)
That video only applies to a radio with no sound whatsoever and that is not your case.
You must inspect your tailgate glass to see if there is any break in the defroster grid. You must also inspect the coax cable that runs form the radio to the tailgate to see if it is broken or frayed.
On the door lock issue, did you just purchase the truck with these issues or they were working before.
Your theory of both rear door actuators failing is not realistic. Since you are the new owner, you have no no idea what the previous owner did or didn't do. They could have failed at different times, not together.
When you lock the truck with the remote, do the lights in the exterior mirror blink three times?
You seriously need to get rid of that super outdated MCS. The cheapest cars made - Kia's - have better head units than the MCS now. Spend the money and get an updated head unit that has all the modern comforts.
Relay #23 opens the right front door and both rear doors. So if the right front door opens when using the remote it would seem that the previous owner disconnected the wiring harness connectors to both rear doors at one time or another.
Remove a rear door of your choice and check to see the status of the 4 wire connector located up towards the door handle. If it is disconnected, then you will have to replace both rear door locks.
Use the proper tool to save breaking the clips.
