Rear SAM program
Rear SAM has nothing to do with foglights. There is no "programming" to make foglights stay on any time motor is running.
To support rear LEDs requires a replacement rear SAM. There's no "programming."
there are REAR foglights, which ARE controlled by the rear SAM.
you DO need a new SAM AND you need to set it to LED mode, otherwise your rear fogs will always be on. it requires Star diag, someone who knows how to use it, and 5 minutes of their time to program it (as opposed to "programming" it )
Hello, i have a problem with rear sam. I changed the rear sam to get led lights. I did it and everything Was Ok, but i recently did a programming of rear sam with newest software in offline mode das. The result is that brake lights is rear lights, brake lights Are fog lights and fog lights are rear lights. Everything is changed without return light and Sígnal lights.
I have a aditional problem about fuel indicator on cluste. Its on 0 position when the tank is full.
I cant now the actual consumption. i did changes on cluster valúes too.
Please help
Please help
Hello, i have no resister in line. I have the original tail led lights, the rear sam And only I have the license plate led with Its resister inside.
I think like you the sam is fooling And change the way it Works
Thanks for you help. I see you have a 320cdi ml.
Now i am installing distronic.
