How to play music from Iphone 5 via Bluetooth in ML350 2008
Old 10-26-2012, 12:47 PM
kumarp99's Avatar
2008 ML350
Hi All,
I have Ipod integration on my 2008 ML350 and I wanted to play music from my iphone 5 via bluetooth, because for Iphone 5 they change the pin which is not compatable to IPOD integration pin. So can someone tell me is it possible to play music via bluetooth, if yes then how?
Thanks,
Praveen
Old 10-26-2012, 02:52 PM
BillsBenz's Avatar
2010 ML350, 2010 GLK350, 2010 C350 4matic
From what i have read on numerous forums, I don't believe Apple has allowed that capability.
Old 10-26-2012, 03:13 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
If you don't mind plugging it in you want this guy: http://store.apple.com/us/product/MD...30-pin-adapter
Old 10-26-2012, 04:16 PM
kumarp99's Avatar
2008 ML350
Thanks for your responses. Do you guys have any idea about Belkin Bluetooth music receiver? does it work?
Thanks,
Praveen
Old 10-27-2012, 01:56 PM
medic's Avatar
2009 ML550
I am using this in my 2009 ML
http://www.ebay.com/itm/Mercedes-Ben...2ab889&vxp=mtr
Old 10-28-2012, 09:27 AM
06e320cdi's Avatar
2008 ML320CDI
Why bluetooth, just plug a male to male stereo cable into headphone jack of Iphone and Aux input in glove box.
Old 10-28-2012, 02:03 PM
For the earlier 164/251 models if you have the iPod you don't have the aux input and visa/versa. Only during the newer models they have dual inputs.
Old 10-28-2012, 02:14 PM
kumarp99's Avatar
2008 ML350
I am not sure I have both AUX and IPOD inputs or not in my ML350 2008, I will check and if it is there then I guess it will be pretty simple. And Thanks a lot for all your ideas.
Thanks,
Praveen
Old 12-09-2012, 10:39 PM
Richard R.'s Avatar
2009 ml350
how to play music from an iPhone 5 on the Ipod interface on an older ml350
Apple sells a coverter. It converts a lighting connector to the older 30 pin connector. 29.00 buck at Best Buy
Old 12-09-2012, 11:24 PM
Per post #3.
Old 01-06-2013, 06:59 PM
Sammydavis's Avatar
2008 ml320
I am not sure that adapter will work. I have a generic version that does not.
Old 01-06-2013, 07:27 PM
AudiA4Turbo22's Avatar
'03 A4 2.0 Stroker, '14 E63 S AMG, '10 E550, '10 S550, '03 C240
If you have OEM iPod integration just get this:
http://www.ebay.com/itm/Bluetooth-A2...90564405467%26
Converts your iPod cable to a A2DP receiver.
Just bought one myself, I'll post my results.
Old 01-06-2013, 08:40 PM
Sammydavis's Avatar
2008 ml320
ok, let us know. The same item on dealextreme has someone saying it wouldn't work in his car. This one is confirmed in an ml320 2007 as working
http://www.coolstream.co/index.php/c...ck-detail.html
Old 02-01-2013, 05:13 PM
commandworld's Avatar
2001 S class
Here is the best answer to stream music, Connect, See your music info on your command screen,control your iPod from your command and steering wheel in your car even at home using Bluetooth. Perfect for iPod,iPhone 4, 4S and 5 and iPad
https://mbworld.org/forums/audio-ele...ml#post5529051
Old 02-02-2013, 11:13 PM
chrissk's Avatar
2015 GLK250
Try this. It works for me. It seems currently sold out but it was under $10. Worth to try. Also available on ebay.
Amazon Amazon
Old 02-13-2013, 12:33 AM
PASHN8's Avatar
'08 C63 AMG
I bought one of these also for my '10 ML350 CDI, will report back
http://www.ebay.com/itm/Mercedes-Ben...70929076361%26
Old 04-03-2013, 02:44 AM
mbfanbb's Avatar
2010 ML350
Hi
Did it work? Can you stream music via bluetooth from iphone5? does COMMAND display song name, etc.?
Old 04-03-2013, 09:59 PM
medic's Avatar
2009 ML550
I mentioned above that i was using the mercedes media interface plus, but actually it does not properly work, for me, with iphone 5. At least via bluetooth - i cannot pick up the songs.
Old 04-03-2013, 11:51 PM
mbfanbb's Avatar
2010 ML350
Can you stream via Bluetooth? I don't care much about seeing song titles. I'm however looking for a way to stream via Bluetooth. Thanks
Old 04-04-2013, 12:36 AM
medic's Avatar
2009 ML550
I was able to with the iphone 4. Now with the 5 I have not been able to...
Old 04-04-2013, 12:41 AM
mbfanbb's Avatar
2010 ML350
That sucks. Thanks for the info. We will have to wait until something comes out I guess. I think MB dropped the ball on this one. iPhone 5 has been out for months and still no solution. Many, much cheaper brands out there can stream music fine.
Old 04-04-2013, 12:44 AM
medic's Avatar
2009 ML550
Not sure what's up. The phone/voice bluetooth works of course. It's just the music part. I may stop by the dealer to see if there is any new COMAND updating to be done, but I did update relatively recently to get the back-up/reverse guide lines on the screen - but that was I think before iPhone 5.
Old 04-04-2013, 06:21 AM
mhammady's Avatar
2010 ML350
Hi,
I tried this device and it DIDN'T work, so pls avoid it
http://item.mobileweb.ebay.com/viewitem?itemId=281048974840
It gives unrecognized device on the panel and my 2010 ML350 won't play anything
Btw, I just ordered a new device which I think can do the trick as it connects to the aux interface and avoid the complicated protocol exchange of the iPod interface
http://item.mobileweb.ebay.com/viewitem?itemId=360502605590
Old 05-03-2013, 02:53 AM
mbfanbb's Avatar
2010 ML350
Hi All,
I bought the tune2air wma1000 and have been using it for a few weeks now. It works great. I recommend it. I can stream from my iphone 5 via BT.
Old 05-08-2013, 08:36 AM
medic's Avatar
2009 ML550
Hi All,
maybe i will try this one as well - i think it's $99
Quick Reply: How to play music from Iphone 5 via Bluetooth in ML350 2008
