ML300CDI Coolant and Windscreen concentrate
ML300 CDI
Hi,
Anyone got a ML300 in Australia? if so what Radiator Coolant should be used to top up?
What windscreen concentrate do you use and the mix ratio?
2008 ML320CDI
Coolant will depend on whats in there, Check color and then get appropriate from dealer. Windscreen cleaner, I use one tube of Summer Fit (MB Product, to 1 gallon of blue washer fluid
hey i got an ml300 and from oz too. If i recall the coolant from the factory a light green/yellow colour. I just bought the one from mb which is blue. I've been using that. hope that helps. For windscreen i just use either water or i add a little car washing detergent. works fine.
MB coolant is blue, but MLs and GLs seem to come from the factory with Zerex-G05 which is yellow.
The formula is said to be the same.
