ML 350 2006 can't open doors via remote control
Old 08-23-2016, 02:45 AM
maverick747's Avatar
ML 350 2006 y. USA ver. VIN 4JGBB86E96A131558
Hi please give me help why I can't open doors via remote control, it is possible only via infrared. I remove old antenna module and put new one. And still not work. I also check fuse and SD. Thanks!
Old 08-23-2016, 11:14 AM
Plutoe's Avatar
Received 1,020 Likes on 948 Posts
1999 E300TD
Who was the bonehead that told you the antenna was bad---go and get your money back-----on the lighter side post your VIN!!
Old 08-23-2016, 11:22 AM
Ok! O do it, I can get back this antenna module. My VIN 4JGBB86E96A131558
thanks for help.
Old 08-23-2016, 03:51 PM
Plutoe's Avatar
1999 E300TD
You will no doubt think that this post is not helpful!!
However,maybe the attachment will enlighten you and others on the complexity of the central locking system and suggest rather than asking bonehead questions, you will find someone who has the diagnostics to quickly pinpoint the fault,else they like you will wind up pissing away money and not solving the problem---there is no free lunch---see a mechanic!!
Quick Reply: ML 350 2006 can't open doors via remote control
