W220 S500 Instrument Cluster
Old 08-10-2004, 05:47 PM
SUHAIL's Avatar
1986 190D 2.5 (W201), 1999 SLK230 (R107), 2000 S500 , 2001 SL500, 2005 G55 Grand edition 327 of 500
Exclamation W220 S500 Instrument Cluster
I wanted to find out, does the instrument cluster package on a 2000 S500, holds its own memory or is just a display for information stored elsewhere.
Example: If the car has X # of miles and the cluster has to be replaced for some reason, will it still record the orignal info, as milage/ avg mpg etc.?
Old 08-10-2004, 06:27 PM
SUNILP's Avatar
2015 E250D
the mileage data is kept in more than 1 spot. You cannot simply swap clusters. You have to copy the data over.
Old 08-20-2004, 12:22 AM
SUHAIL's Avatar
Do you know how that may be done, i.e. copy data over
Old 08-20-2004, 06:23 PM
saturnstyl's Avatar
Once mileage is burned to a cluster it can never be rolled back. Get a new one from a dealer, have it programmed properly, otherwise you will have issues with various warning displays, fuel guage, FSS, etc....
If you cannot read the mileage now, replace the 5 amp fuse that is blown it will likely get you enough light to read the mileage to get the new cluster programmed.
Old 08-20-2004, 06:42 PM
SUHAIL's Avatar
My car is out of warranty, I do not know how much they cost, but I assume they may not be cheap. A local salvage yard has one with approx the same milage my car has, it is now probably 600-1000 more than my car. Could i make the deal with him drive my car approx another 500-1000 or so miles and then switch. It is just a thought, maybe it wont work! Is it worth a try ?
Old 09-13-2004, 10:17 PM
standman's Avatar
cluster
the memory is in the cluster, I replaced my cluster and it kept the mileage of the new cluster. You have to make sure you buy a cluster with the same model number otherwise you may have to go to dealer and have them reprogram it as some features will not work e.g. telephone, etc.. Also, it will show a defective cluster on it.
Stan
Old 09-16-2004, 12:29 PM
fazooley's Avatar
2013 w204 C350
Standman is correct. The mileage is infact stored in the cluster. I believe in the new S the information is stored on an eeprom chip where as to the older ones where you could reprogram the dash via the bonnet under the hood. You can buy one from anywhere and send it out to be reprogrammed for like 200.00.
Fazooley
Old 09-21-2004, 11:02 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
same for W202?
My odometer is messed up too (see below). GDawg suggested buying one on ebay and the ones I found have far fewer miles on them (I've seen them marketed as a way to "lower" the miles on your car!). I don't want to do anything unethical or illegal, but isn't $200 a ton of dough to reset an odo from 53k to 70k? also, how would I be able to tell exactly how many miles are on my car, given the messed up LED's?
Old 10-06-2004, 10:53 PM
FlatRate101's Avatar
06' W164
As mentioned by others, numerous settings in the cluster are "version coded" specifically for the equipment,or lack there of, in your particular vehicle...and just because another vehicle is the same year and model does not mean it has the same equipment as yours, any of these things coded incorrectly can cause malfunctions in numerous other systems....It is best to leave cluster replacement to an MBZ dealer who can transfer the coding to the new cluster. I've seen a few very expensive paper weights come from improper coding.
Old 10-22-2005, 02:40 AM
csumt76's Avatar
LS7 powered Corvette
On a 2000 220 the miles are only stored in the cluster not in both the cluster
and eis
Old 10-25-2005, 10:53 PM
ScottCLS55's Avatar
Lexus
Mbnz dealer is not the best place. They will put it in your service history and they have to tag the door jamb "this odometer was changed" Your lucky a 2000 model is easy to change or program. Look on ebay for people with speedo units, they can reprogram it for you, Junk yard or new(dont give dealer real vin # if you use them, again with the service history crap) 01 and up models have mileage stored in key ignition and the speedometer cluster.
Good luck..
Old 10-26-2005, 01:51 PM
SUNILP's Avatar
2015 E250D
... and EIS
Old 10-26-2005, 09:10 PM
516mbtek's Avatar
'06 CLS55 P030
220 cluster issues
Recomend taking to dealer....swap out the eis and cluster. Version coding will need to be performed on both units. Just had one in the shop, ordered a cluster w/ milage but the old version eis would not communicate..and milage turned into dashes..dont mess around w. this..
Old 10-26-2005, 09:14 PM
516mbtek's Avatar
'06 CLS55 P030
Flatrate is right...
Quick Reply: W220 S500 Instrument Cluster
