2009 ml63 power steering pump
Yes detach AC compressor, remove left front fender liner, detach high pressure lines from oil pan---if this is done in the front yard you are crazy!!
Then there are loads of bleeding and filling instructions for install!!
try changing the fluid.... get steering oil from merecedes, get a fluid pump and remove old fluid, and add new fluid. repeat process in a week, again.
mine used to whine heavy. i just changed the fluid and no more whine.
zenman63 (05-27-2016)
Working on mercedes for the last 15 years.
Done the pump but it still makes a noise! I will try bleeding tomorrow but does seem odd as I did what was advised in wis 30 time back and forth without the engine running to get the oil round.
Any tips?
Any tips?
