S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Replacing Piston rings? s600 1997
Old 10-30-2014, 10:34 AM
Mitchell_NY's Avatar
c280 1998, 2002 C32, 2000 Ford Excursion
Hey guys, took my car into the local shop and they are stating that the piston rings are bad and need to be replaced. Has anyone ever did this before? Car is a 1997 s600. 110k miles on it. I am in Austin texas,.
The shop just installed new plugs, boots and coil packs and it is still giving me misfires.
This car is not my daily driver so, I can afford to wait and take my time with this project.
Car doesnt feel like it has v12 power at all. any insight or tips I would really appreciate it.
Old 11-18-2014, 07:50 AM
syljua's Avatar
1998 C140 CL500
The misfire must have progressed a long time to let gasoline wash
out the bores and destroy the rings. What do they base their statement
on? Have they done a leak down test of the cylinder?
Do they have proper MB DAS Star diagnostics machine (where the cause
of the misfire can be investigated, either by error code, or
turning a cylinder of to see if it gets worse or better). Checking the
cam advance can also be done in Star. Mixture information also.
This german thread shows whats involved when changing rings (well
that engine had gone with unburnt fuel for a long time...);
http://www.w140forum.de/showthread.php?3163
br,
syljua
Old 11-21-2014, 08:59 AM
oldsinner111's Avatar
s320
thoose engines last a long time,unless it was raced all the time.I'd make sure cylinders looked good,and hone them.
Quick Reply: Replacing Piston rings? s600 1997
