S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Can someone tell me if I'm doing this right?
Old 11-09-2014, 03:29 PM
lxpeery's Avatar
1994 Mazda Miata
Can someone tell me if I'm doing this right (Xenon headlight testing)?
Hey all, I signed up for the forum just to ask this question, but hopefully I'll be back often.
Just for a bit of reference, I sell used car parts for a living. Yesterday, I happened across a pair of OEM Xenon headlights out of a 1997 Mercedes S500.
My typical testing method for Xenon headlights is to hook a 12 volt battery to the ballast. On this one though, the ballast has a port, rather than a set of wires. In other words, I don't know exactly what is power and ground. Playing around with terminals, I've gotten the D2Rs to flicker rapidly. Normally, I would say "bad ballast" and move on. However, both headlights have this issue, and in my experience, if you find a set of lights with the exact same issue, it probably means that there's something wrong with your testing setup.
My question is this. Well, questions. One, does anyone have a wiring diagram for the headlights? Two, is there anything special about the S500's that would mean that a 12v battery wouldn''t provide enough current? The wiring to the ignitor is much heavier than any xenon setup that I have come across, and so I'm thinking that maybe there's an amplifier or something that I am missing. In other words, should hooking a battery to the proper terminals work?
Sorry for the jumbled question. Thanks in advance for the help!
Old 11-17-2014, 09:57 PM
lxpeery's Avatar
1994 Mazda Miata
Even a wiring diagram would be very helpful...
