Help needed
1998 s500 benz
Help needed
1.Does 275/55/17 tires fit on front of a 98" s500 without rubbing ?
2. Does 05" ml350 rims fit on a 98" s500?
3. Do you have to take off the bumper to change the window washer pump?
yes on bumper,I don't think ml would work, and tires would rub to high
Window washer pump should just pull off from the windshield fluid reservoir. You will have to disconnect the signal cable connected to it. Writing this from memory, as it's been awhile since I've changed one.
