S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
power steering gear box leak
Old 09-20-2016, 08:44 AM
beebsie's Avatar
2008 S550 4Matic and 2014 E350A Cabriolet
My 1999 S320 is slowing down, may need to replace her. The steering box has a slow leak. I read where Lucas Oil has a product the can stop the leak......one reviewer said for as much as two years. To replace the box would be expensive. Is the Lucas product a viable short term solution?
Old 09-20-2016, 03:22 PM
oldsinner111's Avatar
s320
I bought some power steering stop leak,and it worked took a month.
Old 09-20-2016, 08:23 PM
_Ryan's Avatar
2004 S600 Biturbo
It's not going to hurt the box any. The seals are already shot. It could cause premature pump seal failure but unlikely.
You can rebuild that box. It's time consuming but not terribly expensive. That is the route I would go. Those stop leak products RARELY work.
Old 12-10-2016, 11:48 AM
rosswell's Avatar
S320 GL350
Steering Box Repair
I'm having the dealer replace mine with one from Germany. Over $3K installed. Tired of the drips on the floor.
Old 01-31-2017, 09:03 AM
rosswell's Avatar
S320 GL350
follow up - MB fix
Happy with my S now back from dealer - no drips on the floor. Fresh alignment - Solid as a Railway Train on the highway. Personal choice to spend the money (equivalent to some W140s whole value). BUt it's done right. And still only 71 K on the clock.
Quick Reply: power steering gear box leak
