Adapter/Harness for bixenon headlight-part number?
Old 02-11-2008, 07:05 PM
2H S5's Avatar
2011 Sienna SE, 01 S500, 05 LS430 UL
Question Adapter/Harness for bixenon headlight-part number?
Does anyone have or know how to look up a part number for the adapter on the
autolevel feature for the bixenon headlight?
I already traced the wires for the autolevel from the bixenon headlight and they match up with the old xenon headlights.
I'll post the pictures up when it's done.
S500 man posted the adapter for the bixenon high beams.
This harness is from autowerks.
Hopefully someone will know the part number, I want a clean plug-in. I don't want to start using terminals.
Attached Thumbnails Adapter/Harness for bixenon headlight-part number?-autowerks-kit.jpg
Old 02-12-2008, 01:20 AM
Frank_S500's Avatar
SL63 (R230), CL500 (C215), SL55 (R129), CE300-24 Cabrio (A124)
Exclamation
Required are:
2x A000 153 08 42
2x A220 545 46 28
14xA000 540 38 05
4x A000 540 39 05
Cheers, Frank
Old 02-12-2008, 01:37 AM
2H S5's Avatar
Thumbs up
Originally Posted by Frank_S500
Required are:
2x A000 153 08 42 Adapter for autolevel?
2x A220 545 46 28 Adapter for highbeam
By couting the wires:
14xA000 540 38 05 wires for the 2 adapters (9 for middle plug and 5 for highbeam)
4x A000 540 39 05 wires for the autolevel
Cheers, Frank
Muchas gracias Frank.
Where have you been all this time???
Do you have any info regarding the autowerks harness?
Old 02-12-2008, 05:10 PM
Frank_S500's Avatar
Usually here: http://www.motor-talk.de/forum/merce...lasse-b77.html
No, dont know the autoworks harness. I have re-invented the wheel on my own.
Btw, you'll require the schematics too, in order to succeed.
Cheers, Frank
Old 02-12-2008, 06:44 PM
2H S5's Avatar
Cheers, Frank
Thanks Frank.
Regarding schematics, is it something I have to pay for?
I pulled the wires off the bixenon headlights and the coloring matches with the old xenon headlight.
Are there any other secrets to this or they will match up fine?
Red
Green
Black
Blue
I'll try to upload some pictures tonight.
If I get this to work, I promised everyone here a full DIY
Old 02-13-2008, 01:30 AM
2H S5's Avatar
new pictures
Some new pictures showing the wires for the high beam and the autolevel.
Now to get this to work
Attached Thumbnails Adapter/Harness for bixenon headlight-part number?-l-highbeam.jpg   Adapter/Harness for bixenon headlight-part number?-r-highbeam.jpg   Adapter/Harness for bixenon headlight-part number?-l-autolevel.jpg   Adapter/Harness for bixenon headlight-part number?-r-autolevel.jpg
Old 02-14-2008, 01:23 AM
Frank_S500's Avatar
The autolevel is easy. Its just 1:1 connection.
Cheers Frank
Old 02-14-2008, 01:34 AM
2H S5's Avatar
Cheers Frank
I think I jumped ahead and quote you too early.
Thanks Frank.
That's great to hear about the 1:1 connection.
I'm excited to get this working.
One last thing regarding the highbeam. It's just one grounding wire to the brown one right?
There are some mixed messages regarding the 1st and 3rd wire that need grounding.
Old 02-14-2008, 12:19 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
the ground is easy just get a ground wire...ground it in the engine bay, and plug it in the hole nearest to the grill..........in that little mb adapter.
Old 02-14-2008, 12:32 PM
2H S5's Avatar
Thumbs up
S500 Man, so for the Right(passenger) headlight, it's the brown one.
You can see that little plug beneath the headlight.
On the left (driver) headlight, it'll still be the brown wire-for everyone else to see.
Check back for the DIY since you didn't get the autolevel to work
LEFT HEADLIGHT:
Old 03-10-2008, 07:22 PM
ArMaNi S500's Avatar
2000 Mercedes S500
Ok I'm a bit confused. I was thinking to update my 2000 lights to an OEM set of Bi-xenon projector updated headlights. I was under the impression that all I need is some kind of harness that will allow for an easy install? Is that correct or am I completely mistaken. If someone can school me on how I'd have to go about making the conversion I'd appreciate it.
Old 03-10-2008, 10:19 PM
S500 Man's Avatar
its pretty easy look up my thread....
Old 05-28-2008, 09:01 PM
2H S5's Avatar
AUTOLEVEL UPDATE with new pictures!!!!!!!!
Sorry to those who pm me and I never answered back. I've been away from mbworld for awhile. Here's an update and mcssci had an excellent write up also while I'll provide the pictures
In conjunction with mcssci:
https://mbworld.org/forums/s-class-w220/242394-diy-bixenon-upgrade.html
4. Assemble your wires into your 4-pin auto level plugs:
Insert the female ends of the A000 540 38 05 wires into the back of the new (4-pin) A000 153 08 42 plugs until they click into place.
Cut off the male ends.
The new plugs are labelled 1-4 next to each wire.
Cut the wires to the old plug and splice them to the new wires, matching blue to 4, black to 3, red to 2, and green to 1.
2 high beam plugs (5-pin) A220 545 46 28 (left)
2 auto level plugs (4-pin) A000 153 08 42 (right)
cables for autolevel and ground. Quantity should be 10.
autolevel plug from car
color properly aligned
first spade plugged in. this is if you don't want to use the splice-in connectors.
plugged in to headlight
grounding for highbeam (notice they're both on the left for L and R headlight)
Old 12-19-2008, 07:22 PM
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Will this work for my friend's 2002 W215 CL500 upgrading to bi-xenon headlights?
Old 02-01-2009, 06:48 PM
BUMP!
Old 01-25-2012, 02:02 AM
Twins05's Avatar
S430
Hi
I am driving S 430 , 2001 and 2 days ago I asked the dealer to estimate the price for the Bi-Xenon . He told since my Original Headlights are Halogen is a lot of work to put in it and this is going to cost me $ 5000 .
Any suggestions ?
Old 01-25-2012, 04:46 AM
classyS's Avatar
2001 S430
http://www.ebay.com/itm/AUTO-LEVEL-0...ht_4026wt_1163
they pre-wire for halogen and xenon, just make sure u tell them what u want - everything is plug-n-play (unscrew, screw, plug-n-play)
Old 03-19-2012, 11:57 PM
blackraven15205's Avatar
2000 S430
Adapter Harness Found 00-02 W220
Anyone out there searching for the elusive adapter that I myself began to doubt its existence...Eureka! http://web13.server001.publicompserv...n-Harness.html
I verified via email with a company rep that this is indeed what is needed to avoid any splicing, complete plug in play for xenon to Bi xenon.
Old 03-20-2012, 01:34 AM
classyS's Avatar
2001 S430
very nice find blackraven15205!!
Old 03-20-2012, 06:42 PM
2000 S430
Thanks, I know there are many out there who shared my frustration of trying to make this work, took me about 3 months everynight searching to track this company down in Germany... struggle no more friends (They take Paypal!)
Old 07-14-2014, 10:00 PM
Mulletmudbogger's Avatar
Bus Honda accord bus
I got them to work!!
After hours of searching this thread gave the exact directions how to upgrade your crappy 00-02 xenon to the 03+ bixenon
If I had to do it again I would probably just make my own connectors for the ground and auto level with some high quality female crimp connectors to shove into the pins on the headlights. All those wires and harnesses cost $80 shipped!
The new headlights are crazy bright compared to the old ones. I plan on selling all the old xenon parts to help pay for the new ones. I got the new ones off a wrecked car for about $300 shipped for everything which is crazy cheap. Which is a good thing because I'm a broke student.
Old 07-15-2014, 12:42 PM
01 S500. Looks so much newer.
Attached Thumbnails Adapter/Harness for bixenon headlight-part number?-image-1971864316.jpg   Adapter/Harness for bixenon headlight-part number?-image-1683885945.jpg
Old 10-20-2018, 04:54 AM
OV Auto's Avatar
w124, w126, w215, w220, r129, r107
Guys
Thanks for the efforts and sharing.
I have a 1999 S500 with Xenon but want to convert it back to normal headlights.
The old light inside wires are completely toast combined with the broken plastic clips which were suppose to hold the light.
There are only two plugs, one the main like with all and another 4-pin plug which I assume is for the self leveling system.
Can you advise on how the wiring needs to be changed; e.g. is it the same like putting in the ground wire for the leveling or is it more complex?
Appreciate your help.
Old light
standard plug old light
4-pin plug self leveling
new none xenon headlight
one plug only to connect all
Old 01-26-2019, 01:32 PM
bigblack315's Avatar
CLS500
Free Bi Xenon Headlights if you help me !!!!!!!!!
My car has by xenon headlights factory I want to convert it to a projector I purchased some projector lights and there for Halogen models what do I need to do wiring wise to get these lights to work on my car which is originally for by xenon...... whoever can help me make these lights work I will ship My xenon lights to them and they’re in perfect working order. clear lenses and all they work perfectly. Just pay for shipping and you get My Bi xenon lights Free
Last edited by bigblack315; 01-26-2019 at 01:34 PM. Reason: Changed title to get more attention
Quick Reply: Adapter/Harness for bixenon headlight-part number?
