best way to lower my car on 22's
clk,s-500
i heard about some sort of module i can get for around 1000 that over rides the air ride..is there any more ways i can lower it?
https://mbworld.org/forums/s-class-w...-drop-car.html
Safe, cheap, and easy. Easily reversed as well. I lowered mine in about 30 minutes. I didn't replace the front bolt as I didn't go super low. (1 inch or so)
clk,s-500
2012 CLS63 AMG Performace - Obsidian Black
Uhhhh... I guess I'd have to ask why on earth you'd want to put 22" rims on an S-Class, but it sounds like you're set on it. That being said, I'll tell you that you've picked the wrong suspension set-up for such a no-doubt fabulous display of bling.
Your lower ball joints and links (already weak when paired with only 18" AMG rims) will punish you with creeaaaakkks and squeeeaaaaks within months, letting you know that yet another $300 visit to the indy (or $500 at the dealer) is due! Be prepared for multiple replacements.
Also, speedometer, ESP and other rather critical functions will be non-calibrated. Well, good luck anyway.
Stick with 20s.... 22s will just make it look ghetto with most rims. There are a very few # of rims that look good in 22s on these cars.
Also you usually need to RAISE a car to fit 22s, not lower it. So be sure to test fit them before lowering
clk,s-500
well thank you all for your input but i like the bling look and i dont know if 20's will look to small on it..how much can i lower with 20's? i want a 3 piece wheel also
with 20s you can do a nice drop, look at the picture thread at the top of this forum , here are some nice ones dropped on 20s
https://mbworld.org/forums/s-class-w...thread-39.html
on 22s you arent going to be able to get that tucked/dropped look, you are going to look like a scraper or donk. Which is fine if you hang out in the ghetto trying to talk like a rapper, but looks stupid everywhere else
2000 Mercedes Benz S500 Designo
Like OliverK said, 22"s and lowered are a lost cause.
Just curious, if you were to upgrade to 18"s or 19"s, could you recalibrate the speedometer, odometer, etc?
As long as you pick a tire size of the same diameter as stock , you dont need to recalibrate anything. Its not the wheel size that affects it, its the diameter of the tire.
Since most 18s and 19s have skinny sidewalls, the overall diameter is about the same as the factory setup.
One easy way to compare is to go to tirerack.com, see what the diameter of the factory tire size was, then look at the diameters of various 18s and 19s to see which ones most closely match
clk,s-500
search ebay or this forum for
mercedes lowering module
Those will cost about $1400 new or about $700 used. Plus installation.
Personally I would recommend the washers method linked above. Even if you have a shop do it , it should cost under $200.
