transmission dipstick s430??
Old 04-29-2010, 06:40 AM
tusabes's Avatar
Mercedes
i have a 2000 s430 , from what i read in these forums there is no transmission dipstick, just a "cap" that can be replaced with a dipstick, which is a "workshop tool" for checking fluid level.
Is that correct? And if so, where can i purchase the dipstick at the best price? Ebay only has one for a 2003-2006 s430.
and where in the engine compartment is the "cap" i need to remove to replace with the new dipsitick?
Thanks in advance
Old 04-29-2010, 08:48 AM
cameraman123's Avatar
2000 Mercedes Benz S500 Designo
The cap sits on the engine at all times. It can be removed to use the dipstick, but you will have to replace it with a new cap. The dipstick is a workshop tool and can be purchased online. I'd do a google search. The 03-06 had the exact same engine to my knowledge, but the 7 speed tranny went in in 2004 so I'm not sure if it uses the same dipstick. The dipstick tube can be found by the passenger rear area of the engine compartment, almost under the air-box assembly.
Old 04-29-2010, 01:01 PM
Quadcammer's Avatar
96 and 08 911 turbos
not entirely true. You don't need to replace the cap, just the tab that prevents the cap from coming off.
Old 04-29-2010, 03:22 PM
shellshock's Avatar
2001 Mercedes S500
http://cgi.ebay.com/ebaymotors/1996-...#ht_2742wt_943
Old 04-29-2010, 05:57 PM
tusabes's Avatar
Mercedes
thats the one I saw on ebay, but it says it only works with 2003-2006 s430.
Mine is a 2000 s430.
Old 04-29-2010, 06:36 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Actually the header says 1998-2002 but it must work for your car not 2004 thru 2006 because these models have the entire fill tube deleted.
The big listing that shows 2003 thru 2006 S430 is wrong. I don't know where he expects it to go if there is no tube. maybe just a general compatibility hart but it's incorrect. This may be the correct tool for you.
Old 04-29-2010, 07:22 PM
tusabes's Avatar
Mercedes
thanks, i just bought it at autoanything.com , free shipping and at least if it doesnt fit my model i can return it.
Is there anywhere that has trans fluid checking instructions, like how to remove the cap, etc? Are we supposed to check it while the car is running like on most other cars? I know the instructions say dont leave the dipstick in there.... so im wondering if you arent supposed to check it when the car is running.
Old 04-30-2010, 09:36 AM
Quadcammer's Avatar
very simple.
Removing cap: Locate cap with plastic tab. Pry up on plastic tab until it breaks. Use screwdriver to push lower part of tab through the bottom of the cap (into your hand). Now the cap can just pull off.
The fluid level is checked when the vehicle is running. The reason they say not to leave it in there is because the dipstick is about 12" longer than the tube so it flops around. It is a measuring tool only.
Make sure you get your hot and cold temps pretty close to the 20c and 80c that are listed on the dipstick.
Old 04-01-2014, 04:11 PM
Mellimel's Avatar
2003 MB S430
Thumbs up Very Helpful
I found this information very helpful, as I need a dipstick for my 2003 MB S430, dealer sells it for $112. pre-order and I found it on ebay for $17. New.... Thanks a million
Old 04-01-2014, 09:07 PM
tusabes's Avatar
Mercedes
How did you find it for $17?
I searched ebay and the $17 ones are the engine oil dipstick , not the transmission dipstick . Those are $30++
What is the eBay item number
Old 04-03-2014, 05:12 PM
Former Vendor of MBWorld
ECSTuning's Avatar
2012 SLS AMG
If anyone is interested, we have the the genuine Mercedes-Benz dipstick tool for the 722.6xx Automatic. This is the same tool that is used by Mercedes-Benz technicians at the dealership to measure the fluid level in the 722.6xx during a service.
The 722.6xx Automatic Transmission is used in the following 220 Chassis S-Class models:
S430 (2000-2003)
S500 (2000-2003)
S600 (2001-2006)
S55 AMG (2001-2006)
S65 AMG (2006)
You can get to the dipstick tool on our website HERE or by clicking on any of the photos below.
We also have the Dipstick Tube Cap Lock Pin available as well. You can get to it by clicking HERE, or by clicking on any of the photos of the Dipstick Tube Cap Lock Pin below.
Along with these items, we have a wide variety of genuine Mercedes-Benz as well as aftermarket parts for your Automatic Transmission. Simple select your vehicle from the drop-down menus on our website, and go to Drivetrain>Automatic Transmission
If anyone has any questions, please feel free to post or send a PM!
Old 07-05-2019, 11:41 AM
JackPara's Avatar
Mercedes benz 2003 S430
Hello, Can any of you give me the exact dimension of the area marked in red.
Quick Reply: transmission dipstick s430??
