2000 S-500 How to reset Service-B...
S500 & BMW 745Li & C6 Vette
Could you please tell me how to reset the service B light ? And also what you call and to buy that little antenna on the roof sitting on the back glass ?
Much appreciated for any support. Thanks
2005 S500 4-Matic, 1978 450SL
Please let me introduce you to the W220 S-Class Owners Start Here sticky at the top of the W220 forum main page, https://mbworld.org/forums/s-class-w...tart-here.html. Stickies are written to address items that come up frequently, so that answers don't have to be repeated.
You will find links to resetting the FSS under "Resets" in the sticky. There are different procedures for different models.
The antenna to which you refer is often called the "Shark Fin" antenna, though that is not its formal name. It is the Global Positioning System (GPS) antenna for your navigation system.
Mr. Skylaw, Very well explanation... Thank you so much for the help. Much appreciated, Sir.
Will look into that. I was searching around as well, but unfortunately had no luck. And with your link, hopefully I can go beyond.
Thanks again. t_clealy
1 Post
2005 S500
Reset FSS Button A is the (R) button on the right next to the instrument cluster.
Button C is the top left on the steering wheel
Button B is the bottom left on the steering wheel
Turn ignition to position 1 (engine not running)
Press B until trip/mileage appears on dash
Press C until service symbol and distance appear
Press A for 4sec until DO YOU WANT TO RESET etc appears.
Release A and within 5sec press until new service shows
Release A
Turn off ignition
and u r good 2 go.
Release A
Turn off ignition
and u r good 2 go.
Release A
Turn off ignition
and u r good 2 go.
Release A
Turn off ignition
and u r good 2 go.
And Also Thanks to my friend, Skylaw.
You guys are the best!!!
