Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W220)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 06-17-2012, 01:43 PM   #1
Drives: 05 S500 4m
4-matic Transfer Case Fluid Change DIY
sorry guys, no pics, but here are the steps:
1. Lift car...duh. I used ramps up front, stands in the back, making sure the rear wheels can spin. Also make sure the car is level.
2. Remove heat shield. There are five 8mm bolts/nuts around the perimeter that need to come off. Only the small heat shield in the front needs to come off.
3. Put the car in neutral. use the T60 torx socket on the 3 bolts that connect the flex disk to the output shaft flange of the TC. you'll need to hold the backside nut with an 18mm open ended wrench.
4. Once the three prop shaft bolts have been removed, you need to push the prop shaft back off the TC output shaft flange. I needed to pry a bit to get the flexdisk to come loose.
5. Now, use a 6mm allen socket to loosen the fill plug. You may need to spin the TC output shaft flange a bit to get the best angle at it. I would not use an allen key here. Loosen the fill plug, but don't remove it. Just leave it a turn loose.
6. Now use a jack to support the transmission. I used a hockey puck right infront of the tranny crossmember.
7. Remove the 6 16mm bolts that hold the tranny cross member on.
8. Remove the 3 13mm bolts holding the tranny mount to the cross member
9. Remove the 4 t-50 torx bolts holding the tranny mount to the transmission. I did not have to remove the rubber from the mount, but keep in mind one t-50 bolt will have interference with the center mount bolt, so remove the other 3 first and let the mount drop, then remove the 4th.
10. Now use your 6mm allen socket to loosen the inspection and fill holes. Let fluid drain completely. Use a new copper washer and reinstall the drain plug. Torque to 30nm or 22lb ft.
11. Use a fluid pump to put .6L of fluid into the fill hole. Keep in mind that there is an obstruction about 1/4" inch into the fill hole, so you can't insert your filling tube in too far.
12. The TC is full once the fluid runs out the inspection hole, you can reinstall the inspection and fill plug (with new washers). Same 22lb ft.
13. Install is pretty much the reverse of removal. I don't have the torque specs in front of me, but they are around if you search.
Pretty straightforward, but a lot of parts removal for a routine task.
To remove this ad, register today or login if you already are registered!
__________________
05 S500 4m & 96 993TT
Quadcammer is offline   Reply With Quote
Old 06-18-2012, 08:54 PM   #2
benz_addict's Avatar
Drives: V12TT
Nice DIY. How often is this service required? How many miles on your car? Did you feel any difference in noise or response?
__________________
S600 V12TT - S65 cluster, S65 exhaust, Brabus ABC ELM, CL65 gloss black wheels, delimited
benz_addict is offline   Reply With Quote
Old 06-19-2012, 08:29 AM   #3
Drives: 05 S500 4m
I believe its once every 40k miles. I have 44k miles.
Car drives the same, which is to say well. I did notice a slightly loose flex disk bolt, and tightening that seems to have helped a slight highway vibration I have.
__________________
Old 06-20-2012, 07:50 PM   #4
Drives: V12TT
Oh ok. Thanks for the information, it will be handy to me. About to pick up a w220 4matic for my father
__________________
Tags
4matic, benz, case, change, changing, diy, fluid, matic, mb, mercedes, noise, s500, transfer, w211, w220
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
