s500 wheels rubbing
Old Jun 17, 2012 | 11:47 PM
paha93's Avatar
2001 Mercedes S500
s500 wheels rubbing
I had some amg wheels lying around from a 2006 cls500 sport (the twin spoke design 8.5 in front and 9.5 rears)that i decided to try on my 2001 s500. The front wheels are fine but the rears rub inside the wheel wells. The current tire sizes are 255/40/18 and 285/35/18. My question is will replacing the tires to 265 or 275 eliminate the problem?
Old Jun 18, 2012 | 12:26 AM
desired_speeds's Avatar
2007 SL55 AMG
depends how much it is rubbing by
Old Jun 18, 2012 | 12:49 AM
paha93's Avatar
2001 Mercedes S500
just the inner lip
Old Jun 18, 2012 | 10:20 AM
stevedel's Avatar
W220
i believe the stock tires sizes for those wheels should be 245/45/18 & 265/40/18.
Old Jun 18, 2012 | 03:23 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Your rubbing problem is most likely related to improper wheel offset miss-match from the CL to the "S".
And the CLS:
Old Jun 19, 2012 | 04:22 AM
paha93's Avatar
2001 Mercedes S500
Ye offsets were a problem so I put spacers on but they were way to wide so I bought shorter lug bolts from the dealer. Now they're fine just the tires rub a bit. I'm going to try putting a 265 in the back see if that solves it
Old Jun 21, 2012 | 05:13 AM
tusabes's Avatar
Mercedes
It should fix it
