lots of problems :((((
#76
You might ask them about sending both units and see if they can give you one back that will work with your car and key.
#78
We don't know what got wet , only you do.
Everything electrical that got wet should be considered damaged . Even if it work now it will fail once corrosion gets worse
#79
1 Post
S500L 03, Avalanche 03 and Porsche Cayenne S 04
Both front fuseboxes got wet nothing else. Everything inside works just fine. I do get esp malfunction message. Not cranking and fan going full speed could be caused by getting water in the ecu from what i read, could the sam or anything else cause this as well?
#82
Received 2,144 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Rechecked all fuses and all are good. I did not check the relays i remember now.
I then got under the car to check for the starter and i can't feel any click, nothing. So i guess no power and no need to take out starter. Taking out the starter seems pretty difficult by the way. Does that mean ECU is faulty? Cable seems fine although i can barely see it.
So i took out right front sam, the one next to the ecu. There are a few marks of water no rust though. I will order a new sam anyway. Sam is plug and play i have read. Can someone confirm this because i had also read that ecu was plug and play. I think i will wait for the sam to arrive and if that does not fix it i'll send the ecu to Miami for repairs.
What is all this costing you in total?
#83
1 Post
A lot of money. Which i would not have had to spend if i had put back the covers.
Ok so far i ordered 2 sams
Transmission, , esp and suspension computer i have not bought yet, costs a lot more and is difficult to find. I will ship the ECU this week to the repair guys.
#86
Unfortunately I was not exaggerating .
There may even be additional damage due to the water as there are many other electrical components in the engine compartment besides the fuse boxes too
#87
If you are willing to go to the trouble, you can try cleaning each of the units. Washing with pure alcohol will sometimes get things working again. If you can't get alcohol any other way, 180-proof gin, vodka, etc. will work.
A friend and I cleaned the transmission module in his S430, and that go the transmission shifting properly again. Almost a year ago, and so far, so good. We used brake cleaner in a spray can, but we were cleaning ATF, with no water. Alcohol will do better on the water...
#88
1 Post
The TCU for one did not get water in it. It got tranny flood. I never thought a car with less then 20k miles would give me so much trouble. I read in other topics that it might be saved. If not i'll have to send it to the ecu repair guy as well because the tcu as the ecu needs to be programmed by dealer it seems.
#89
1 Post
The transmission shifted fine when i drove the car last time 2 months ago. I'm going to clean it using contact cleaner, i used contact cleaner for the ecu as well but that did not fix my no crank, fan full speed problem. I have to wait for the sams to arrive to try anything now since i broke one open and it does not seem to close ever again. I'll ship the ecu to the repair guy in Miami this week, it will take about a month to get it back. I'll try alcohol for the suspension and esp computer if i can't find them cheap on ebay by the time the ecu arrives.
#93
I have been and will continue to follow this thread for weeks!! I wish you so much luck and I want a victorious outcome for you!
#95
1 Post
I opened the tcu to clean it and the condensor has come loose. I have a tcu from a w211 with other part number but it is exactly the same. All chips and numbers on the circuitboard seem to match. There are some rusty spots on the board.
#96
The loose component appears to be fairly common. The polarity is critical. If you can tell from the solder or the impressions on the board, great. If not, do some research on line - there are some photos showing this. Sorry that I don't have a url or reference for you. Just be certain to get the polarity correct!
#98
Yep, that's the rascal! Thanks for posting the photo - this might really help the next person with the problem.
Skylaw - It would be great if this photo could make it to the encyclopedia.
