Brake light stay on.
Old 05-01-2016, 01:09 PM
MbNeedshelp's Avatar
1994 w140 s350d
Question Brake light stay on.
My 2001 S500 brake lights come on as soon when I start on the engine and will not extinguish till I turn off the ignition. The Brake light is on inside instrument cluster . I checked the brake fluid level and its full, the Emergency brake is released . I noticed it happened right after I jumped the car with a portable jumper box? Does any one any ideas, and where can I get a diagram of all the fuse and relay locations ?
Old 05-01-2016, 02:42 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
hope this helps i found it for another family member not to long ago.
Save as a pdf. and you can zoom in I do realize its tiny sorry.
Attached Thumbnails Brake light stay on.-mercedes-fuses.jpg   Brake light stay on.-screen-shot-2016-05-01-2.39.44-pm.png   Brake light stay on.-screen-shot-2016-05-01-2.39.57-pm.png   Brake light stay on.-screen-shot-2016-05-01-2.40.21-pm.png
Old 05-03-2016, 11:28 AM
1994 w140 s350d
Exclamation Brake lights not working
Now I can check what the missing fuses are for. Do you happen to have a wire schematic on that system ? Thank you again for your thus far.
Old 05-03-2016, 11:42 AM
MB Marko's Avatar
The only one i have is for the dashboard as that was the issues he was having. So thats the only thing i attempted to find, other than what i already posted.
Sorry i wish i had more but maybe someone else can chime in if they have it.
I just did a quick search on google and came up on this http://www.justanswer.com/mercedes/7...-turn-off.html
not sure if it will be helpful but its a similar issue.
Old 05-03-2016, 12:04 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Have you checked your brake light switch? Here is a you tube video from a ML but the S-Class might be in the same general area.
Old 01-24-2019, 02:37 PM
Akbar Service's Avatar
2007 S600
We are posting to this old thread in hopes of helping those who may be searching for an answer. We see this all the time on W215/W220 models - Brake lamps are on anytime the key is in position '2' - In STAR/Xentry, it's easy to check the operational status of the brake lamp switch. It is also easy to check the signal status of the Rear SAM. In almost every case, we replace the ESP/PML/BAS control unit and the problem is solved. Leave the key on for 15 minutes. The ESP/PML/BAs control unit will be hot to the touch with this type of failure...
Quick Reply: Brake light stay on.
