Is this an issue?? (Steering wheel)
I noticied that my w221s steering wheel does not go all the way up. It adjusts but does not go all the way up. Is there a problem?
We all have trouble getting up sometimes with age.. lol.. is there a way to reset it or calibrate it? I would measure and compare with someone here who can get it up all the way?.. no, I'm not trying to be funny lol
For some reason, when I turn on the easy entry/exit feature, it does not seem to work but It used to when I first bought the car. I have programmed my seat on memory 1 if that helps. I will post pics later.
Have you tried unplugging the car battery and letting it sit for a half hour? Let it reset fully? May re calibrate
About the steering wheel, take a look at the pic, this is how far it goes. The easy entry/exit is currently off and the seat is in my driving position memory 1. The easy entry/exit worked well before I had my driver window reprogrammed.
W126 1987 300SDL
My steering wheel in a 2012 S350 goes up a lot higher. I'm not sure it makes a difference, but I drive with the steering wheel almost all of the way out towards me.
Get it checked out.
Get it checked out.
Received 4,417 Likes
'71 Pinto
I wouldn't be surprised if whatever messed up the easy exit entry feature is the cause here, I would take it back and let them fix that, and there may even be a calibration for the column on Star they can do, or just resetting the module or programming it correctly may do the trick.. The guy above mentioned something though, have you tried moving the wheel in or out and then try going up? If it goes all the way up when you adjust the depth there may be an actual problem in the mechanism.
