Noisy V12 2007
Noisy V12 2007
Ok, guys, I need help!
I have a 2007 S600 with over 100k on the clock, which has developed a ticking noise from the left hand side of the engine at tickover/idle.
I am not sure if it goes when revving the car, as I can't hear over the general engine noise.
Do these motors suffer from any particular problems? Lifters maybe?
It has had regular oil and filters, so don't think it needs that.
HELP, it's driving me mad.
2012 S600
I've had several V12 currently have 2007 CL600 I've never has any issues like that. My recco is to take it to shop ASAP, its always better safe than sorry when it comes to your engine particularly the V12.
How long have you had it?
Get a mechanics stethoscope and listen carefully. If the sound comes from front of engine it is most likely an accessory bearing or an accessory itself. If you are sure it comes from the head - it is prolly a stuck lifter. Those engines are made to run hard and if not done so will clog up. It could also be other more expensive things, but that is very rare with the v12.
