Ordered loweirng links
Depends on the weather
Here are the pics...I was on a slight incline so the front is a little higher than it is on even ground but I still may drop it just a tad. Either way, it looks a lot better lowered even how it is now with less gap.
Pics look great. I prefer leaving some space like that between the fender lip and tire. Now just do the S63 kit and get it over with. You know it's coming. 😊
Yeah, in my experience they don't care. Are you under warranty? If so and you have a suspension issue swap the OEM links back for that service visit.
I may just keep it like this...on level ground the front fender is about 1/2" from the fender.
Yes, yes...the kit is coming, I can't deny it!
#34
Question if anyone knows: I have PDC in my 600 but I don't have the PDC sensors in the bumpers like my 550 has..? So, when they day comes that I order the S63 kit, I am going to get the no pdc holes version since it doesnt have them now.
#38
This one is for "without ADC sport suspension"
But your car has ADC??
#44
No, there are 4 links for ABC suspension in the 600.
They were already preset for a 1" drop front and rear...I dropped the front another 1/2"...the rear sits perfect at 1".
Seeing as how these are made, if you are good at machining/welding you can easily make these links. There is nothing special about them. The oem links feel so cheap but I guess they are just there to adjust height and don't need to be made of solid gold or anything. They are as light, actually probably lighter than a pencil.
#45
Ive been planning all of almost the same mods except when I have the wheels off I also want to add the akebono pads, some 20's , slight drop, and freshen up the calipers. Great Job!!
#48
#49
only rear wheel drives have ABC suspension ?
bout to order this link but just making sure before i do =)
i got 2013 4matic so i should get one without abc suspension correct?
#50
