Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > S55 AMG, S65 AMG , S63 AMG (W220, W221)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S55 AMG, S65 AMG , S63 AMG (W220, W221) Discuss the S55, S65, and S63 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-26-2012, 09:10 PM   #1
Busa196's Avatar
Drives: 221 S65- eurocharged ecu tune, lowered, K1, factory chromies
V12 issues.....winter gas blend
My s65 had 4-5 rough starts back around Xmas time.....it would sputter, cough then stall....then after a few off/on cycles with the ignition and a couple start attempts it would finally start and run fine- my Actron told me the code was a multiple cylinder misfire......ie, the whole drivers side cylinder bank was on the Actron. I bring it in to my dealer assuming it was a near-bad coil pack and I was told that there was no issue with the car, or the coil pack. My tech (as sharp as they come) told me that the refineries have changed their winter blend of gasoline and it's causing the ecu/car to misfire then throw the codes. He said he had seen 13 v12s in the past 3-4 weeks for the same issue, including 2 from the owner of the dealership......and they all had the same codes/symptoms. The best part?....there's nothing they can do until amg writes some updated software to deal with the issue, and that's not expected to be completed until summer time. It wasn't the end of the world as it only happened 3-4 times over 40-50 starts and it only happened at start up and then ran fine.
Now, my car hasn't thrown the code on start up in 4-5 weeks, instead it's throwing the C/E light and misfiring when the car gets under the slightest load/boost. I literally cant let the car downshift from any gear too fast, or too aggressively or it'll throw the light and go into limp mode......which requires me to pull over, turn off the ignition, and restart the car to get it to run/idle normally. So I bring it back in to the dealer last week and my tech was out, but another amg tech advised me that it's still the gas issue. Im now only buying 1/4 tanks of gas at a time praying to find one without this "blend". I've now ran 3, quarter tanks of gas though my car from 3 different stations/refiners and it's still having the same issue and throws a misfire on cylinders 10, 11 and 12.....or all 3 every single time I get the C/E light.....and I can produce it at will. The fact that i continually get the codes from The same 3 cylinders make me think thats its not a fuel issue this time? I would think if it were fuel, it would be an entire side of the motor, or both sides.....not the same 3 cylinders everytime It's agonizing to drive and is arguably not even safe.
Is anyone else experiencing this? I'm in Houston and can't possibly imagine tha every v12 Rollin around town has issues like me? Am I really supposed to continue driving this 200k dollar "flagship", big, bad azz, luxury sedan with misfires and check engine lights until refineries decide to change the refining receipe???? Or until AMG has time to find a solution???? Are you kidding me?..
To remove this ad, register today or login if you already are registered!
__________________
Previous:
2000 ProCharged C5 550rwhp/515rwtq
2002 Heads/Cam C5 440rwhp/420rwtq
2005 ProCharged C6 600rwhp/535rwtq
2006 S65 - 11.54@122 100% stock on DR's
585rwhp/844rwtq with ECU tune
Current
2007 S65 with ECU tune, 2008 Z06, '81 CJ7
Busa196 is offline   Reply With Quote
Old 02-27-2012, 01:30 AM   #2
Drives: 2005 Mercedes S600, 2004 Mercedes E500 4-Matic, 2002 Mercedes C32 AMG, 2001 Trans-Am WS-6
Had a similar issue with my S600. I drove it around lightly for several hundred miles, but any load over 4k rpm threw a misfire. Hate to say, but in my situation, it turned out to be a bad coilpack. Runs like a charm now and I'm in Chicago w/the same BS winter fuel blend.
marktan is offline   Reply With Quote
Old 02-27-2012, 07:13 AM   #3
Sounds like the dealership is full of it. I would look at the coilpacks as well.
Check out line #27 in this post.
Ongoing Maintenance and Repair for a 2003 S600.
Good luck, Johan
__________________
2003 S55 AMG
DRTYLNDY is offline   Reply With Quote
Old 02-27-2012, 07:32 AM   #4
Drives: G350 Bluetec
The OP have given good advice.
Have you used Techron regularly? If not start using it! It makes gas issues that lead to misfires too go away. In my part of the world I use only Shell 93. Excellent gas.
Hope this helps.
grane is online now   Reply With Quote
Old 02-28-2012, 10:41 AM   #5
Flight Test's Avatar
Drives: Buick T-Type, 70 cuda, S65 and a very FAST Truck!
Busa, I did not have the difficulties with start up but I did have problems awhile back about the car throwing codes under load. Just like yours it would run bad until you turned it off and restarted it, then it would run fine until you went into boost again. It ended up being a bad coil pack. The good news was that once the coil pack was replaced it ran much better and just sounded better and more clean at high RPM.
The car is noticiably quicker with the new coil pack.
Good luck
Flight Test is offline   Reply With Quote
Old 02-28-2012, 05:02 PM   #6
pas
Drives: 2007 S65, 2005 Nissan Armada
I had a similar problem, it is not the gas, mine turned out to be a bad ignition switch. Of course they only figured that out after changing all 24 spark plugs and bleeding the intercooler. I had to change dealers though the people at Benz of Coral Gables were idiots. Benz of Miami is much much better.
pas is offline   Reply With Quote
Old 02-28-2012, 06:27 PM   #7
Stephen04E55's Avatar
Drives: '12 ZL1
similar issues on my S65 with 33k miles and would give misfire/limp mode with check engine light. It would happen under load only as I could grandma drive it all day and it would be fine. Replaced the coil pack on the driver's side with spark plugs and it is now fine. I would doubt fuel would give it such an abrupt check engine unless the OBD saw a misfire. "Winter fuel" is a lame excuse IMHO. I could understand some cold weather chugging or slight stumbling but nothing like you have stated.
__________________
'03 S600 Designo Silver/Stone. 10.58@132.46(sold)
'06 S65 AMG. Black/Java with chestnut wood. Keyless go and parktronic. 11.231@125.27 1.748 60' (sold)
'12 ZL1 Camaro. Air intake, pulley(13psi), 90mm TB, tune, drag radials. 11.02@126.1 1.62 60'
Stephen04E55 is offline   Reply With Quote
Old 02-28-2012, 06:49 PM   #8
Drives: '12 ZL1
what makes more sense logically....You can produce a CEL at will due to a random winter fuel issue or a CEL due to a bad ignition coil that always points to the same cylinder? Your argument is solid and those techs need to listen to your specific scenario.
__________________
Old 02-29-2012, 01:50 PM   #9
Oxygen's Avatar
Drives: W220 S65 AMG
Send a message via AIM to Oxygen
Sounds like a coil pack to me. I had similar issues... drive it like a grandma all day and all is well. Anything above 4K RPM would instantly throw a CEL and go into limp mode.
__________________
https://www.facebook.com/v12TT
| Past Cars: Photos
| M275 V12 biturbo technical resources (under construction): www.v12tt.com / www.v12biturbo.com
| YouTube: S65 AMG Video
Oxygen is offline   Reply With Quote
Old 02-29-2012, 01:51 PM   #10
Oxygen's Avatar
I had a similar start-up issue too... brought it to the dealer they said there is no codes and the car starts fine for them.
I bring it home and it's doing the same thing again. I changed the oil, cleared everything with SDS and now it starts like a champ...
Here's an audio clip of my car on warm start: http://www.v12biturbo.com/site/_upload/w220s65start.mp3
__________________
| Past Cars: Photos
Old 03-03-2012, 10:45 AM   #11
Busa196's Avatar
Update- once my tech was back from vacation he looked at it and immediately called me to tell me it was a coil pack, drivers side. He replaced it and I had my car back in 24hrs......runs perfect now. This is a perfect example of why I only trust MY tech......the only time my car has ever been misdiagnosed was when my tech was on vacation. Go figure.
__________________
Previous:
Current
Old 03-03-2012, 10:50 AM   #12
Drives: '12 ZL1
Glad it is fixed! Winter fuel...not!
__________________
Old 03-08-2012, 11:41 PM   #13
BBBSS's Avatar
Drives: 03 E55 AMG, 06 Harley Road King Custom 99 Ram 3500 Cummins, 97 Firebird Race Car, 88 Cutlass Project
Wow you god *&^# tool, stop bumping up old @$$ threads in random sections with your rant. This is not how to get help.
BBBSS is offline   Reply With Quote
Old 03-09-2012, 08:23 AM   #14
Drives: 2005 S55
GEEZ it Looks like BBBSS needs to get some more sleep...talk about rants...
Mike
mrbenzes is offline   Reply With Quote
Old 03-09-2012, 02:18 PM   #15
Busa196's Avatar
Quote:
Are you talking to me, tough guy?
__________________
Previous:
Current
Tags
2012, blend, california, dates, fuel, gas, gasoline, mb, motor, problems, s65, sputter, start, v12, winter
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
