MM Package and Memory Card - SDHC
Old 09-30-2007, 01:03 AM
stealtheo's Avatar
2002-C230k 2005-C230K-SS 2005 Infinity G35 2008-C350
Those that have the MM Package,
You can use the new "SD-HC" format
HC- High Capacity. I purchased a sandisk 6-1 card reader $15-
(make sure it can read SDHC) and also a 4gb SDHC (on sale at CC for $49-)
and the head unit can read it no problem. Hols about 1000 songs in mp3 format and about 1200-1400 in wma format. It's also very fast.
Old 09-30-2007, 01:05 AM
MBfan21's Avatar
2008 C300 Luxury 4matic
So you insert it into that little PCMI slot and it will list the track lists on the center console?
Old 09-30-2007, 01:11 AM
Almost a Member!
Muzic's Avatar
Does the MM screen display the artist/song title if you are playing from a CD?
Old 09-30-2007, 01:17 AM
stealtheo's Avatar
Yes. That little slot is much deeper than it looks. The card reader is as wide as the slot and about 3-4 inches deep
Make sure it has the SDHC logo if you want to use the HC type
Old 09-30-2007, 01:18 AM
stealtheo's Avatar
Yes, as long as it finds that cd in the gracenote database
If it does not find it you can always burn the cd to the hard drive then name the tracks yourself using the control knob or the keypad
Old 09-30-2007, 01:22 AM
MBfan21's Avatar
when you insert the card into the slot, do you also need to have the card reader attached?
Old 09-30-2007, 03:01 AM
stealtheo's Avatar
Yes, the reader goes into the slot all the way (flush) nothing sticks out.
I leave the 6-1 card reader in the car all the time. i only remove the memory card when i'm adding more songs.
Old 09-30-2007, 11:47 AM
MBfan21's Avatar
Sorry I am a little confused. But you have to have it attached to the memory card reader too in the car?? Can't the SDHC card work in the slot without the memory card reader? Or the memory card reader is a must to get it to play in the C class.
Edit.. oh I am looking at your memory card reader now. How does that reader work with the computers at home as I don't see a USB connection on it. It says your computer needs to have a PC card slot. I don't have one of those on my computer. Just USB.
I guess I need to buy one of those memory card readers that plugs in via USB to let me transfer the songs to the SDHC card and then another memory card reader to plug into the center console to read the songs from the card? The card won't work alone?
Old 09-30-2007, 04:10 PM
MBfan21's Avatar
I read the description of the 6 in 1 adaptor. It doesn't list SDHC capable. Unless there is a special adaptor for SDHC cards. And it says maximum storage is 1 GB? You were able to get 4 though.
Read and write (with capacity limitations) to SD, MultiMediaCard, SmartMedia, Memory Stick, Memory Stick PRO, or xD-Picture cards
- SD (up to 1GB)
- MultiMediaCard (up to 128MB)
- SmartMedia (up to 128MB)
- Memory Stick (up to 128MB)
- Memory Stick PRO (up to 1GB)
- xD-Picture cards (up to 512MB, none M or H)
Works like a removable hard drive on any computer or notebook with a PC Card slot
Rugged and reliable with a protective stainless steel cover
Old 10-02-2007, 02:00 AM
MBfan21's Avatar
Anyone else know?
Old 10-05-2007, 01:59 PM
vistapoints's Avatar
Palladium Silver C300 MM
Anyone else know?
I emailed SanDisk about this and this is what they said:
"Please be informed that SanDisk does not have a PC Card adapter that could read SDHC cards. However, SanDisk launched the Multi Card Expresscard Adapter that could support SDHC high capacity cards among the memory card types it supports."
There are other SDHC PCMCIA readers out there. In retrospect, I think I should have gotten the iPod integration kit. Makes things a lot easier.
Old 10-05-2007, 03:38 PM
mb_horseshoe's Avatar
2008 C300 Sport
what about compact flash?
What about using a PCMCIA compact flash reader and using a compact flash card, you can easily get the higher capacities...
Anybody know?
Old 10-05-2007, 07:20 PM
2PHAST's Avatar
500E Signal Rot
You need a Compact Flash type III reader for those type III large capacity drives. Normally, type III readers are thicker, the real question is though, can the MB headunit accept a type III compact flash adapter?
Old 11-02-2007, 01:11 AM
stealtheo's Avatar
- SD (up to 1GB)
The thumb I attached may be old model. New model will do SDHC and it is able to read my 4gb no problem.
As far as how to get the mp3's on the card. The memory card also included a "usb adapter" that is SDHC compatible. The card reader and meory card are both "Sandisk"
Old 11-02-2007, 02:07 AM
stealtheo's Avatar
Sorry, They gave you bad info. they may have not updated the website.
The new version of the 6-in-1 PC Card Adapter DOES support SDHC, trust me I have it (I will try to post a pic). It shows 6 icons on the card and it shows the SDHC right on the card. Also Sandisk has just released a 8gb SDHC memory card.
Here are the pics for the sandisk 6-in-1 reader I have been talking about that sandisk says they DON't have. Notice the SD-HC icon on the card.
Attached Thumbnails MM Package and Memory Card - SDHC-imga1861.jpg   MM Package and Memory Card - SDHC-imga1862.jpg   MM Package and Memory Card - SDHC-imga1863.jpg
Old 11-02-2007, 02:13 AM
stealtheo's Avatar
The C uses pcmcia - that's why you need the adapter.
When you buy the 4gb or 8gb sandisk memory card, you can also purchase it with the "MicroMate" usb adapter
It really is much easier than it sounds. Get the pc card, get the 4 or 8 gb memory card. Copy your mp3's to the card from your pc or laptop. Insert into radio while already turned on and it will auto switch to the card and that's it. Can see the track and info on both the speed o and MM displays
Old 11-02-2007, 11:18 AM
Almost a Member!
ryanrohaley's Avatar
2008 C350 Sport / Steel Gray / MM / AMG
Now I'm a little confused. What is the interface on the MM system? Is it native SD? I'm fine with getting whatever data/music onto an SDHC card, but what kind of slot does the card plug into?
BTW, If you're only dealing w/ an SDHC card (and not the other 5 formats), you can just get the USB reader for your PC and plug the SDHC card into it. A quick search shows that this can be obtained for under $10.
http://factoryshoestore.com/product/..._Reader_Black/
Old 11-02-2007, 07:48 PM
stealtheo's Avatar
No, It's PCMCIA. That way you can use whatever you want. I use what is posted above. I have attached both the card reader and the memory card. The memory card comes with the adapter for your computer also. (MicroMate usb adapter)
the one you posted make sure it supports SD-HC the HC stands for High Capacity - They make a 4gb and an 8gb. I have the 4gb and it works fine.
Old 11-02-2007, 07:58 PM
stealtheo's Avatar
Headunit supports - PCMCIA Type I and Type II 16 Bit Full size
I only chose to use a card reader so I could have several fomats of memory cards to use. The new SD-HC are compact and currenlty 4gb and 8gb
I like this better than my Iphone / Ipod interface because all info is displayed on the MM screen and speedo screen, where the iPod is only on speedo screen
Old 11-02-2007, 10:57 PM
Almost a Member!
In that case, why play around w/ an 8GB SDHC card? They make 120GB PCMCIA drives.
Hmmm...so would it work is the question???
http://www.engadget.com/2007/04/18/s...nd-hard-drive/
Old 11-03-2007, 09:38 PM
MBfan21's Avatar
I can't find the SanDisk 6in1 reader anywhere! The one that supports SDHC. Did they stop making them ? They seem obsolete almost.
Old 11-05-2007, 01:40 PM
stealtheo's Avatar
i bought it at Circuit City only like 2 weeks ago brand new release
Old 11-05-2007, 01:59 PM
stealtheo's Avatar
2k on a 8gb mem card plenty for me, plus the additional 4gb hard drive and 8gb iphone adds another 3k of music
Also the memory card response time very fast and has no moving parts, withstands hot and cold temps better than the hard drive will.
Have not tried a PCMCIA hard drive buy native format for the car is SD and Compact Flash. I was surprised to see the SDHC did indeed work.
Old 11-05-2007, 07:06 PM
Moneymike's Avatar
2008 C300 Sport
what can we buy and where can we buy it?
Old 11-05-2007, 08:31 PM
wase4711's Avatar
2008 c300 luxury, P2, MM, Capri Blue Metallic
burning a 20 cent dvd with 4.7 gigs of music on it seems so much more logical to me....
Quick Reply: MM Package and Memory Card - SDHC
