No reverse lights
1999 CLK 430 W208
No reverse lights
No voltage at the rear bulbs. I am checking to see if the reverse switch in the gear selector is good. Is there a way to replace/repair the switch or does the whole selector unit (202 267 0537)need to be replaced?
I am getting an open circuit at the S10/16s2 when the selector is in the reverse position. This is the bottom socket with the two gray/yellow wires in one of the connector pins and a blue/black wire in the other pin.
Voltage was not present at either pin when the unit was installed with the ignition on and the selector in "reverse"
Thanks in advance!
Thanks in advance!
