helpppp plzzz stereo!.
Old 07-31-2016, 04:10 AM
Atk_gaming's Avatar
2005 e55 amg, 2005 audi s4, 2000 audi a4 1.8T (big turbo)
ok i just have one question where in the world is the stock oem amp for the w211 e55 amg i check trunk i checked under the plastic cover on trunk where is it? also do our e55 amg use the fiber optic speaker wiring or none?.
Old 07-31-2016, 05:55 AM
green1212's Avatar
2004 MERC E55
amp and fiber optics
the actual amp is merged with whats called the audio gateway. and its hidden in the trunk on the drivers side under the paneling against the wall on the drivers side rear quarter panel. its really hard to see but when you remove the carpet panels from the rear, you will see all the wiring going into the rear sam module (where the fuses and such is right there) but further back behind it and about 6 inches towards the front of vehicle from there you will see many many wires going into a square "amp" or better known as audio gateway module. there are 2 screws that holds it suspended on that side panel. 2) the wiring to speakers are your "normal" 18-20 gauge wires, no fiber optic wiring that connects the speakers but the major components have fiber optic hooked up to them and this is whats called the "loop" ie- the cd changer, head unit, nav unit, voice/telematics, sirius if available ..... the fiber optics only connects the major components and right on into the audio gateway module. hope this helped??
Old 07-31-2016, 12:25 PM
Atk_gaming's Avatar
There u go ok ok so i ran into this out of all these wich a my working with? Number 1, 2 or 3?
Old 07-31-2016, 01:14 PM
Atk_gaming's Avatar
I found it !! Dam sneaky s***
Time to re wire this dam thing
Old 07-31-2016, 02:10 PM
green1212's Avatar
2004 MERC E55
u got it!!
yep! thats it man! congrats. and good luck. take care
Old 07-31-2016, 07:36 PM
Atk_gaming's Avatar
Thank you i just finished about 3hrs ago.
Tackled
Swap cut and bolt<br/>
Clean and cover
Bolt close and done<br/>
Thank you once again
Old 07-31-2016, 08:10 PM
forcefed4door's Avatar
05 E55, 06 Audi S4
Which stereo you go with? Or still using stock?
Old 07-31-2016, 08:15 PM
Atk_gaming's Avatar
Yes oem factory radio.
Old 08-02-2016, 01:35 PM
05 E55, 06 Audi S4
Wow, surprised you didn't change it out while doing all that work.
Old 08-02-2016, 02:32 PM
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
could you list to us what you did and what hardware you used?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 08-04-2016, 11:57 PM
Atk_gaming's Avatar
Sorry for late reply.
Ok so oem stereo is coming off it sucks and the autopilot is trash.
Im running:
-Oem front tweeters
-Ds18 2 way speakers on all 4 doors about 65rms to each one
-4 channel hertz amp class a/b supplying 65rms @ 4ohm x4
-mono block hifonics @1ohm 1200rms
-12" sub image dynamics @1 ohm 1200 rms
-clarion deck vx405
-sealed ground shaker box 1.6cu.ft at optimal size for the sub.
-tapped into the oem harness running rca to rear only everything else intact.
Nothing over kill ok sound system not to heavy kinda light.
Deck
Sub and deck
Any questions feel free to ask.
Old 08-05-2016, 12:13 AM
Minty Fresh's Avatar
2006 E55 AMG
Good for you. The stock system blows, but I can't commit the $$ to a ten year old car to upgrade it. For now I'm playing digital files from a premium player through the AUX jack, and running the stock HU on "Standard" sound instead of "Logic 7 Surround." I was surprised to discover it actually sounds better on Standard.
Old 08-05-2016, 12:16 PM
Masri87's Avatar
2006 E55k in Blue Capri
so wait. you didn't have to rewire the car?
Old 08-05-2016, 02:42 PM
Atk_gaming's Avatar
Its old car but worth it i would not sale it, i had to go buy it out of state only a few in california for sale and most are messed up.
No i just used the oem harness and rca cables for inputs from the deck to the amp etc.
Old 08-05-2016, 04:19 PM
Masri87's Avatar
dude. do you have a picture of the stock harness with the OEM cables?
I'm using a xtrons android head unit, i bought the avin fiber optic adapter and i'm using the stock harmon kardon amp still... and which amp did you buy that supported all the channels we have?
Old 08-05-2016, 04:37 PM
Atk_gaming's Avatar
This
Old 08-05-2016, 05:05 PM
Masri87's Avatar
Not seeing the harness to RCA?
Old 08-06-2016, 01:56 PM
Atk_gaming's Avatar
Ill take a picture when i get off work , and btw it sounds amazing better than that oem crap we had , the only downside is u gotta unplug center speaker and both left and right front speakers under the dash by your legs bc those are 8ohm and will fry ur amp.
Old 08-08-2016, 06:52 PM
SPONSOR
hachiroku's Avatar
i thought all the speakers in the W211 were 2 ohm?
__________________
-BARRY
Old 08-08-2016, 07:18 PM
Masri87's Avatar
Thanks.
I don't really wanna unplug center speaker but if the sound range is better with aftermarket amp then why not.
no. the center speaker is 1.5ohm for example
Old 08-08-2016, 07:57 PM
Atk_gaming's Avatar
Thanks.
Yea center speaker is 1.5ohm bottom speakers by leg room is 8ohm and even the sub is 8 or 16 think and doors are 4ohm, but does not matter just ditch them all they suck i just run 4 and 2 tweets total and its dam loud
Old 08-10-2016, 02:21 AM
Atk_gaming's Avatar
Rca inputs
Old 08-10-2016, 08:18 PM
05 E55, 06 Audi S4
I actually think the harmen karden sounded pretty decent for a stock system. I just changed the terrible oem nav out. Brought out much better base and overall cleaner sound with stock speakers and amp.
Old 08-10-2016, 09:16 PM
Atk_gaming's Avatar
Try good aftermarket and u wll change your mind
Old 08-11-2016, 12:52 PM
Masri87's Avatar
where'd you get the harness
Quick Reply: helpppp plzzz stereo!.
