C63 AMG (W204) 2008 - 2015
Urgent advice needed for HID ballast replacement!
Old 08-10-2016, 11:45 AM
shaun.barnard's Avatar
'09 ML 500 (550) Off road Package
Hi all my ballast has failed due to moisture in the headlight, I found another one online but don't know if they are compatible. The plugs and pins look the same but that is as far as my knowledge goes regarding these things and the part numbers differ. It is also from a pre facelift W204 and mine is a 08 W204. Can anyone assist me in making the right call to buy this one. Thanks
This is the ballast for sale with different number.
Ballast for sale pins.
My original faulty ballast pins.
My original faulty ballast number
Old 08-11-2016, 04:32 PM
c63er's Avatar
09 C63 AMG
A 08 is a pre-facelift as well.
Old 08-11-2016, 04:40 PM
Thanks I know that.
Well according to the specs on each they are exactly the same as well as the pins so i dont see why it wont work so i purchased the thing so leta see.
Old 08-11-2016, 07:52 PM
Mort's Avatar
The specs appear to be the same. As long as it is compatible with the SAM I think you will be good.
Old 08-21-2016, 02:37 PM
Installed the new ballast and light is working fine but getting an active lighting inoperable error message on the dash now. Would the ecu need to be reset or could it be some hardware problem? Not much help on the interweb with regards to this.
Old 08-21-2016, 05:22 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
I think you need to make the picture in your sig bigger. I can't quite make out what's going on there.
Old 08-21-2016, 05:33 PM
Then zoom in......
Old 08-28-2016, 03:24 PM
bump
Old 08-28-2016, 09:02 PM
jptaylor's Avatar
2009 C63 P30, 2008 Grand Cherokee SRT8(RIP)
The ballasts are NOT necessarily 100% compatible between cars as far as FULL functionality goes...they should ALL physically light up your D1S low beam, H7 high beam, turn signals and eyebrows but as you found out the ALS functionality may not be present....if you open up your bad ballast you will see that it is not like other HID ballasts that are strictly for lighting off the hid bulb but that there is actually a very complex processor board that found inside...and with this being said there is no guarantee that the new one will have the ALS components.... BUT AGAIN, they will ALL physically work ALL of the actual light producing components inside your headlight
Old 08-28-2016, 11:42 PM
Merc63's Avatar
C63 AMG
I have one of these with the lighting that moves.
Old 08-29-2016, 12:01 AM
jptaylor's Avatar
Looking to get rid of it?
Old 08-29-2016, 02:26 AM
Merc63's Avatar
C63 AMG
Sure, what are they worth?
Quick Reply: Urgent advice needed for HID ballast replacement!
