H&R Coilovers FS
H&R Coilovers FS
I did some swapping and trading and ended up with an extra set of H&R coilovers. Good shape and very low miles. Estimate is 5,000. Buddy of mine decided to trade on a new 911 and these where only on the car for half the year or so. $750 Shipped in the USA.
I have the same set of my 2012 Coupe.
Yes, in fact they are "for a sedan" as H&R only makes in model for the w204. They work well on both the coupe and sedan from what I've seen. These came off a sedan that was traded in for a 911. I have the exact same set on my coupe.
https://www.ecstuning.com/News/Merce...009_2010_2011/https://www.ecstuning.com/News/Mercedes_Benz_W204_C63_AMG_HR_Performance_Coilover _Kit_2008_2009_2010_2011/
I thought mine where stiffer but after my buddy swapped his back to stock his road the same as mine. I've had no issues with my set and I'm fairly low with no rubbing at all. I do a lot of mountain driving and uneven roads and I'm happy with my set. The car is kind of a monster truck at stock height and they help a lot with the looks. As for performance, I don't notice a lot but it does seem very solid in the corners. I normally run with BMW M1 and a 911 and I have no issues hanging with them.
I normally ship 2nd day as I get a shipping discount on air. Due to the weight they may have to ship ground which is like 4 days. I use FedEx. I would cover the shipping cost. The issue is I will be working and the earliest I can ship this week is Thursday. I'm a pilot and I'm home for many days then gone for 4-6 in a row.
thanks.
Eric.
thanks.
Eric.
Price update to $600 shipped. They can leave on Monday or Tuesday and be to you before the end of the week.
Again these are technically for C63 W204 sedan but the figment is exactly the same for the coupe and they only make 1 option for the W204. They fit all W204 except 4 matic.
thanks! Shipping FedEx.
Received 2,810 Likes
Springs don't pull to the right if installed correctly. Spring manufacturers wouldn't be in business very long if they did.
Yeah but I have H&R springs installed by a reputable shop in queens and they have pulled since day one. They've been inspected by the dealer as well as my personal mechanic and everything is fine but they pull slightly.
I have H&R springs, and like most people who have them my car runs straight as an arrow. So, no, these coilovers won't make the car pull in any direction unless the guy installing or doing the alignment is completely incompetent. Now back on topic.
I personally believe the "pull issue" can be several things. #1 is alignment and toe/camber. But I also believe that variance in the springs and rates can cause the issue.
I have this exact set on my car. It drives completely straight.
The added advantage of adjustable coil overs is plainly the more adjustment. You can tweak ride heights and also corner weighting. This allows for more adjustment to get your setup right.
Each to their own. These is not KN's high $ setup, but they are made in Germany and nice quality with more adjustment options vs springs.
Sold
