2015 mercedes glk250 bluetec wont start
Old 08-24-2016, 05:26 PM
zazlouz's Avatar
2015 mercedes glk250 bluetech
im strugling on starting my flooded 2015 glk250 bluetec.
i cant even get it to turn over , when i put the key in and try to start it nothing happens but everything else is working fine all the electronic is on.battery is good , auxilliary battery is good, fuses are good, relays are good. i wonder if its not the starter that i shot dead.
any help will be appreciated
thanks
Old 08-24-2016, 06:24 PM
107123210's Avatar
GLK250 2014
thanks
Isn't car under warranty? Just call the dealer and have them come and pick it up.
Old 08-24-2016, 07:27 PM
Cwdawson's Avatar
Fj cruiser 2014 GLK250
Flooded? is this an insurance write off... if not warranty would be the way to go...
Old 08-24-2016, 08:49 PM
zazlouz's Avatar
salvage no warranty
Old 08-25-2016, 07:54 AM
symphony's Avatar
2013 GLK250-BT
Hydrostatic lock could be the cause if the vehicle was submerged enough to allow water into the intake.
Old 08-25-2016, 02:09 PM
Mmr1's Avatar
2013 glk 350
Are you posting this here, recently twice, under different names and titles?
Old 08-25-2016, 03:32 PM
bop11's Avatar
350 GLK, C280
If it really was flooded and you were lucky enough not to have the engine running when it happened, you might be able to save it. If you can't crank the engine, it is hydro locked. That means that there is water in the combustion chamber. Water is not compressible so the engine will not crank.
Pulled all the injectors, ALL the injectors. Remove the air cleaner. Crank the engine to push the water out of the cylinders, it should rotate easily. Replace the injectors and replace the oil and filter. The fuel should be good but you may want to drain the tank and replace the fuel.
Replace the injectors and air cleaner. If the electronics did not get wet, the engine should now start
If the engine was running when it flooded, you probably bent some rods along with other damage, so the engine is toast.
Old 08-29-2016, 09:33 AM
bop11's Avatar
350 GLK, C280
What did you pay? Car maybe worth $30k if running and low miles. If you paid less than $10k, you could have an Indie work in over for $15K and and be in the ball park. It is an investment. But the clock is ticking! In a few months it will be a 2 year old model.
Old 08-29-2016, 10:44 AM
zazlouz's Avatar
the car is only 3000 miles and i paid 15k for it.
i think the problem is from the adblue system cause all the codes that come out are from it: P13DF00, U029D87, P24AFFD, P2BA9FD.
so im trying to find out a way to bypass it.
Old 10-12-2016, 11:04 PM
zazlouz's Avatar
hello every body
i finally got the car started ))
it wasnt a peace of cake im telling you.
and now am seeking your help for the trany.
its not shifting right and sometimes its not shifting at all
no codes found neither on the cdi nor vgs.
the tranny was dry from the oil i did fill it up following wis asra with atf134 from mercedes but looks like something wrong with it that i can t figure out since there is no fault code .
any help will be appreciated.
thanks in advance.
Old 10-13-2016, 08:09 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
A mechanic with a STAR system will need to research the tranny connections. Sounds like you might have an electrical problem in the harness.
Old 10-13-2016, 09:32 PM
autoworrks320's Avatar
93 500e. 15 GLK 250
15 bt
salvage no warranty
Was it worth the $15k?
Old 10-14-2016, 06:27 AM
Mmr1's Avatar
2013 glk 350
Was flooded before you got it? A friend of mine drove through an open fire hydrant kids had opened, it got the trans computer wet, instead of getting a new computer and having it programmed to the car, he found one at a junkyard for 100$, he said they only need to be programmed to the car once. If nothing local, Ebay a trans computer cheap. For a 100$ and a few minutes swap it's worth doing.
Quick Reply: 2015 mercedes glk250 bluetec wont start
