GL Class (X166) 2013-2015 after facelift became GLS (X166)
Boost Pressure + Back pressure sensor 350 CDi M642
Old 09-26-2016, 07:27 AM
Adrenaline1971's Avatar
W212
Hi There,
I am having a GL 350 CDi going in limp mode with with 2 faults registered : 2510-1 : Check Component Y 77/1. Boost pressure regulator. positioner signals Fault
2616-2 : Check Component B60 (exhaust back pressure sensor control variation) . Exhaust back pressure is too high
I did replace the back pressure sensor, cleared the faults and after a long test drive same problem, car goes on limp mode and faults re-appear.
Any ideas ???
Old 09-26-2016, 08:41 AM
Plutoe's Avatar
1999 E300TD
You did not complete the job---replace the faulty Y77\1--charge air positioner!!
Adrenaline1971 (11-09-2016)
Old 09-26-2016, 09:12 AM
W212
Part No ?
Dear Plutoe,
Thx what is this part ?
Would you have its part no.?
Many thx
Old 09-26-2016, 10:00 AM
Plutoe's Avatar
1999 E300TD
Many thx[/QUOTE]
Post your VIN!!
Old 09-26-2016, 10:13 AM
W212
VIN
VIN : WDC1660572A062222
tHX
Old 09-26-2016, 02:32 PM
Plutoe's Avatar
1999 E300TD
tHX
Nice try, that VIN is for aa african 276.955--
Old 09-27-2016, 12:24 AM
W212
Why Nice try ?
Yes the Car is in Mauritius
Old 09-27-2016, 05:57 AM
Plutoe's Avatar
1999 E300TD
Read your first post---you say you have a GL 350 CDI---that's a diesel---now in post five you post a VIN, however it is for a gas car------my question is what is the real car and what is the VIN for that car not your girlfriends car!!
Old 09-28-2016, 01:06 AM
W212
Plutoe you mae me have doubts
Thought maybe that i was starting to have Alzheimer lol ....
The Car is a GL 350CDi as per below:
M276 - V6-GASOLINE ENGINE M276
M35 - DISPLACEMENT 3.5 LITER
Any idea ?
Thx
Old 09-28-2016, 07:47 AM
Plutoe's Avatar
1999 E300TD
Yes an M642(diesel) is not the same as M276(gas) and the M276 does not have the boost pressure regulator Y77\1
Any ideas?-----wait for Thaipusam
Old 09-28-2016, 08:16 AM
W212
looks like you are smoking .... :smash
Old 09-28-2016, 08:20 AM
W212
I m a fool , gave you the wrong chassis ...
Old 09-28-2016, 08:28 AM
W212
Oops ....The right VIN Is : WDC1648222A454062
Any ideas?
Old 10-11-2016, 01:47 PM
W212
Ordered a brand new Turbo .... Hope it will solve the issue as the boost pressure regulator is not sold separately
Old 11-09-2016, 01:30 PM
W212
Talking Great news
Finally replaced the turbo by the latest superseded part no. And now the car drives like a charm.
Thx Plutoe
Old 11-23-2017, 07:15 AM
Ronin Miller's Avatar
Gl350 bluetec
Dear Sirs, your kind advice is kindly appreciated.
I own a GL350 bluetec 2012 diesel with 150 thousand Km onboard. We have replaced the inter-cooler radiator due to an accident and one intercooler hose connected to the throttle valve.
The faults accuring now are the B60 Internal fault in the Back presure sensor (actual and B28/8 differentila pressure sometimes)
We have replaced the DPF even though the old one had good values, checked the Turbo which seemed to be perfectly working, the turbo module is also working fine. Cleaned the EGR which was also working fine. We are going crasy with this car..
the car idles with low back presure about 650 while specified range is (700-2000) and jumps to 3000 or to 4600 values at boost. The boost reaches up to 3000 rpm and never more.
can somebody advice pls
Old 09-16-2022, 03:47 AM
Radubb's Avatar
C207 E350
Hi there,
I have the same problem with the back pressure, at idle is normal , but while driving it goes up to 4.3 bar. At the same time my dpf wont complete its regeneration cycle due to a high temperature of the b19/11 sensor.
I have replaced parts worth 8000€ in this car and I have the same problem.
would you be so kind to let me know how did u sort your problem?
Old 09-16-2022, 06:48 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
High back pressure due to clogged particulate filter. Use liquie moly dpf flush kit.
Old 09-17-2022, 01:29 AM
Radubb's Avatar
C207 E350
The dpf is brand new and we have the same problem.
Quick Reply: Boost Pressure + Back pressure sensor 350 CDi M642
