iPhone Media Interface Cable?
GL550
Trying to hook up an older iPhone 4s for the kids (loaded with movies) but our model year GL (2015) comes with the Media Interface Cable with the lightning connector which does not work with the 4s (30 pin). I have also read that the lightning connector is only digital and would not support the analog signal coming from the older iPhones anyway.
Just curious if I were to buy the previous cable a few model years back that has the 30 pin connector if that would work? Something like this maybe: http://www.ebay.com/itm/2013-to-2015...hU83i8&vxp=mtr
These are the two posts that I have been reading and re-reading but can't really make heads or tails as to whether anyone has gotten this to work....
https://mbworld.org/forums/gl-class-...014-gl450.html
https://mbworld.org/forums/gl-class-...ml#post6276198
The first thread basically says only way to get it to work is hook up using AV adapter kit to rear dvd system and then using BT audio (possibly to work through car speakers).
The second thread gives the idea that someone actually got both video and audio to work using the media interface cable but only talks about certain generations of iPods and not sure if it will work with the 4s or not.
Can anyone provide an update if this works or not?
Thanks....
Thanks....
2014 ML350 2w, 2017 GLS550, 1967 Pontiac GTO 4 sp
What is on the other end of the lightning cable, i.e. how does it plug into the console? We just got a '14 ML350 with the 30 pin connector. One end is male and the other female. I bought a 30 pin to lightning adapter to see if I can connect up my SE and my wife's 6. I guess the point of this is to make the steering wheel controls work the phone. I haven't tried bluetooth for a/v yet, just the phone. I think the steering wheel controls in my Durango control the iPhone when it is bluetooth connected for a/v. You can take a ride to a dealer to see if you can borrow a 30 pin but that depends on how it connects to the console, hence my question above.
GL550
One end is the proprietary connection from MB that plugs into the slot in the middle console and the other end is the apple lightning connector end that goes to the iPhone: https://www.amazon.com/Genuine-Merce.../dp/B00J0FQVBI
But like I stated the iPhone 4s does not take the lightning connector but instead is the old 30 pin. I was also thinking maybe I could try something like this: http://www.ebay.com/itm/like/151452753386?lpid=82&chn=ps&ul_noapp=true
I doubt that it would work though....any thoughts?
I have the old 30pin connector for my 2014 GL450. It is connected to an old iPod 60GB from around 2003 (??). I have some videos on it (MP4) and they do play on the (nav) screen (I don't have the rear entertainment video screen).
However, like with playing DVD with the built in player, it will only do so when in Park. With DVD playback, you can unlock it with VIM but I'm not sure if that will also enable playback via the iPod/iPhone 30pin interface.
Does this answer your question? The cable on mine is supposedly OEM. Mine was a CPO and the previous owner did not leave it behind. So the dealership ordered a replacement for me. I had asked for a lightning cable but they said 30pin was what came with the vehicle.
Grey.Spectre (09-29-2016)
GL550
Not sure if that will make any difference but I guess it's worth a shot. Do you happen to have the part # for the 30 pin media interface cable so I can make sure I get the correct one?
The link you included above on eBay appears to be the correct item. I should still have the packaging material from my cable. I'll look for it and follow up if I do find it.
The 3.5mm is actually a video/audio combo. I have yet to figure out how to get that to work. I bought a 4 pin AV cable for a DVD player but couldn't output the video from DVD player to the COMAND screen.
Anyway, back to the iPod in question, not all MP4 files will play. I have 6 videos on the old iPod from 2003 but one of them will not play. It is more of a novelty for me at this point so didn't dig around too much on the file differences. Basically, to play, I select VIDEO and then pick the media interface device as input. Most likely it will not show you a list of playable files. That's ok. It may even switch to AUDIO input instead. Just do a search and select video. It shows up as ALL/ALL on mine. Picking ALL again it will then show me the list of videos found on the iPod player. From there I pick the video files and it'll play.
This is from memory. If you still can't get it to work, let me know and I can make a short video when I'm at the car.
Ok. I'm at the car. Clicking on Video, I do see also DVD-Video and Aux. Now move the toggle down to Media which is the bottom row selection. From there you should be able to see the iPod device. Selecting it, it kicks me to Audio.
So I guess it doesn't matter if I'm in video or not in hindsight.
From Audio now, select Search at the bottom row of interface. Scroll all the way to the last item and it says "Videos". Next, select "Movies" then "All" then "All" again. My list of movies are showing up. Selecting one of the movies, it should play.
GL550
I just got my 30 pin media interface cable in from ebay and attempted to hook it up. It shows the source as an iphone under Media like you said and also kicks me to Audio just like you said. The only difference is the Search button is not highlighted so I can not search for any stored movies. If I play the movie physically from the iphone the sound starts playing through the speakers but I can not locate the video as you instructed....any other ideas?
Thanks,
Michael
jlim-
Thanks,
Michael
Thanks,
Michael
GL550
Not sure what you mean by trying to play the movies by selecting a Playlist from COMAND....how do you do that?
Also...any possibility it part of the issue could be that I am on an older OS (8.0.2)? I do have an update available (9.3.5) I just have not installed it yet.....
Thanks,
Michael
I resurrected an old iPhone 3G with iOS 4.2.1. Connected it via the media accessory cable.
I went to Audio when Media Interface. Under Search, by default it shows me all the media (songs and short movies as well as full length movies). I push the COMAND toggle to the left a few times (5 times) until I'm back at the main/first screen. I scroll all the way to the bottom and I do see Videos.
Selecting Videos, the next screen shows:
- Movies
- Music Videos
- Rented Movies
- TV Shows
- Video Podcasts
selecting Movies, then select All/All (2 times) I now see all my movies. Not all the movies will play though. And there's no sound either. Maybe I need to also connect the 4 pin 3.5mm AUX to get sound.
Interesting you get sound but no video. Make sure you are in park. Else the video will definitely not work.
- Movies
- Music Videos
- Rented Movies
- TV Shows
- Video Podcasts
GL550
- Movies
- Music Videos
- Rented Movies
- TV Shows
- Video Podcasts
- Movies
- Music Videos
- Rented Movies
- TV Shows
- Video Podcasts
Thanks for digging out your old phone and trying it out for me...I appreciate it. Just a quick ? any idea what file format the movies are in on your phone that play (are they mp4, avi, etc)?
Only MP4 or M4V as I'm playing using the default builtin player.
Those files on the iPod and old iPhones were converted via Handbrake using the individual settings provided (iPod, iPhone).
