SL55/63/65/R230 AMG: SL Black Series Style Hood
Old 10-02-2016, 11:27 AM
rbreaks's Avatar
'06 CL55 AMG, '08 SL65 AMG, '09 e550 4Matic, '13 Range Rover Sport Autobiography
Does anyone have direct experience with this brand and hood?
Seems like a reasonable price. Any input would be greatly appreciated.
http://www.ebay.com/itm/261733180216?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 10-02-2016, 06:59 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
if you never bought any of these aftermkt body parts youre in for a big let down. they always require alot of extra labor to finish and thats if they fit at all
Old 10-03-2016, 09:34 AM
rbreaks's Avatar
Okay, thanks. I guess I'll pass.
Old 10-06-2016, 09:57 AM
rbreaks's Avatar
Against my and other member's judgement I have purchased this hood. I couldn't help it. It arrives in about 2 weeks, I'll let you know what y experience is. Fingers crossed.
kustom2k1 (10-06-2016)
Old 10-06-2016, 07:58 PM
okbarnett's Avatar
hope you have good luck with it
Old 10-14-2016, 02:54 PM
rbreaks's Avatar
The hood was delivered today. Waiting to hear back from the body shop that it arrived without any damage and that it fits without too much of an issue, etc.
The following 2 users liked this post by rbreaks:
kustom2k1 (10-15-2016), vtvette (10-16-2016)
Old 10-18-2016, 11:50 AM
rbreaks's Avatar
The shop reported back that the hood came in without any damage and they'll let me know in a day or two about the fitment. So far, so good.
Old 10-18-2016, 11:42 PM
Ed954's Avatar
R230
Please post some pictures when done
Old 10-21-2016, 10:51 AM
rbreaks's Avatar
Okay, so the body shop took a closer look and the hood is in pretty good shape. They did mention that where the cut-offs are for the new vents/honeycomb area are a little too flexible. In other words, the hood is not as structurally solid and reinforced as it should be. They're going to make it a little more rigid and clean it up so it looks a little nicer, but so far so good. Next step is fitting it on the car to look at how it lines up to see how much additional touching up it needs. Will keep you posted.
Old 10-21-2016, 02:39 PM
BlownV8's Avatar
Received 1,003 Likes on 810 Posts
E55, GLS450, GL63, GLE350
If you don't reinforce the crap out of that hood, your paint will crack in short order.
Old 10-24-2016, 02:06 PM
bayhas's Avatar
SL55, GL450, and 300SE
With all due respect, the cut quality of this thing (not even considering strength and dynamics) is not something I would allow at less than 10 feet from my car, the shop needs to pretty much rebuild that hood from the ground up, before it will be worthy of your car, and at that point, you might as well simply modify your stock hood, and place two scoops in it, if you know what I mean...
Old 10-25-2016, 09:56 AM
rbreaks's Avatar
Bayhas,
You may be right, but that's why I'm sharing this modification for this specific hood. Might work out, might not, we'll see.
Best,
Ron
Old 10-25-2016, 10:04 AM
bayhas's Avatar
Originally Posted by rbreaks
Bayhas,
Best,
Ron
Certainly! Thats the beauty of these forums.
Good luck, i like the mod, and would love to see it completed, one way or the other
Old 11-09-2016, 10:01 AM
rbreaks's Avatar
Okay, so heard back from the shop and there are some issues that we're seeing if we can get resolved by the manufacturer. Issues as follows:
1. Hood adjustments are all the way down and the hood is resting on the rubber seal within the engine compartment.
2. Vent openings on the hood are 1” off from the front of the hood to the openings. This is noticed when the hood is up. The Mercedes emblem area is not centered too.
3. The two areas for the grille opening are very weak for the lack of material. When closing the hood if not careful these areas are going to crack, exposing cracks on the finish side.
Old 11-09-2016, 10:15 AM
bayhas's Avatar
If you're paying for labor to repair all of these issues, there is no way modifying/repairing/installing this hood will be less expensive than modifying a factory one.
I totally understand if you want to keep the factory one untouched for resale purpose, but if that's the case, I highly recommend buying a used one, and modifying it.
To save you some time and effort, the maker of the FG hood will not be able to properly fix it, because even if they replace it for you, they will send you an identical part, as they use one mold to make them...
Old 11-09-2016, 10:41 AM
rbreaks's Avatar
Agreed. It was worth a try, wanted to see if I got lucky.
Old 11-09-2016, 10:44 AM
rbreaks's Avatar
Picture of the hood...
Old 11-09-2016, 10:49 AM
bayhas's Avatar
I know the feeling
been there done that... by experience with ebay body kits, years ago, ended up being similar
Quick Reply: SL55/63/65/R230 AMG: SL Black Series Style Hood
