C450/C43 AMG
Will C63S stock 19" rims fit a C43?
Old 10-23-2016, 07:37 PM
Munajj Ahamed's Avatar
None
Even though I find that the C43 looks like a gem, I absolutely HATE its Rim collections. I know there are aftermarket options but I have not seen any aftermarket rims which looks as good as the C63s stock 19". Those are some beautiful rims and I was wondering if they would fit my C43.
Old 10-24-2016, 01:28 AM
OC6.3AMG's Avatar
W205 C43, C204 C63, & Honda Fit
C63 sedan wheels would fit C43 sedan and coupe, however C63 Coupe would not fit the C43, nor will it fit the C43 Coupe.
Standard wheels:
C43 sedan: 225/45R18 front and 245/40R18 rear
C63 sedan: 245/40R18 front and 265/35R18 rear
C63 S sedan: 245/35R19 front and 265/35R19 rear
C43 coupe: 225/45R18 front, 245/40R18 rear
C63 coupe: 255/40R18 front, 285/35R18 rear
C63 S coupe: 255/35R19 front, 285/30R19 rear
Munajj Ahamed (10-24-2016)
Old 10-24-2016, 11:52 PM
None
Sorry, I should have been a bit clearer. I was just wondering about the Rims specifically. Like will the C63s 5 star 19" rim fit the C43 sedan given proper tire sizes.
Old 10-25-2016, 12:23 AM
Sanch's Avatar
AMG C63s
Is this for the sedan? or the coupe?
Old 10-25-2016, 12:27 AM
None
Sedan.
Old 10-25-2016, 12:40 AM
Sanch's Avatar
AMG C63s
Sedan.
I think they should work.
You can pick them up from here.
Just double check your current wheel offset.
http://www.mercteil.com/en/products/...19-for-c-class
Old 10-25-2016, 09:00 PM
None
My plan was to somehow acquire these rims from someone who is selling it and then put the original 19" C43 spec tires on it. Has anyone here really pushed the offset limit for the kind of rims you can put on these cars?
Old 10-26-2016, 11:11 PM
AMGTTV8's Avatar
AMG
I wouldn't just guess as to what and won't fit...
Look at your operators' manual or one online to figure out what the relative fitments are (wheel and tire combos are usually listed at the back for the entire segment.)
Axles and front fenders are different between the cars which means that differences in offset will be amplified more greatly.
Not as simple as swap and go.
Hope this helps!
Old 10-27-2016, 01:27 AM
Sanch's Avatar
AMG C63s
Hope this helps!
+1
Old 06-06-2018, 03:29 PM
Bernard Fonseca's Avatar
C43 AMG Sedan
After all did anyone get this done? I am currently on the same boat. I found a pair of OEM c63 19'' multispoke wheels at a good price and want to give it a try.
Old 06-07-2018, 02:17 PM
Star4life's Avatar
2017 C43 AMG
front will need approx 6mm-8mm spacer, rear will bolt up. use c63 tires sizes in rear 265/35/19, but use 235/40/19 in front.
this has been covered in c43 wheel fitment guide. i recommend you read.
Bernard Fonseca (06-12-2018)
Old 06-12-2018, 02:04 PM
C43 AMG Sedan
Thank you for your informative response. I got the seller to go with me to a shop to get them fitted. The problem is his fronts are 245, and wont sell without them. Do you know if this will cause any serious issues?
Thanks again, Im super excited!
Old 06-12-2018, 02:17 PM
Star4life's Avatar
2017 C43 AMG
245s would rub if you dont space out far enough. and if you space out too far youll be poking and look bad. buy the rims with the 245s and swap them to 235s after.
Old 06-12-2018, 03:37 PM
C43 AMG Sedan
Thanks! I’m going to get this done tomorrow and I’ll report back hopefully with pictures of them installed already.
Old 08-03-2018, 10:30 AM
jawlee's Avatar
c43
Talking
Looking at going c63s OEM wheels on my c43.
Any updates? How does it look?
Old 03-01-2022, 05:14 PM
rangy's Avatar
250d Blue Tech sport C Class 205
C63 saloon/sedan 5 spoke alloys fit onto the c43 coupe no probs with a 10-15 spacer on the front *your choice) rear bolt on fine, as long as you dont go above 235 tyre front, 265 tyre rear its all good, i have the set up it on my C43 now
Old 03-02-2022, 10:35 PM
SilverBullet18's Avatar
C450,GLC 63,VW GTI
There is a guy running c63 front with 245 tires he has a 6mm spacer to basically make it et32. (Stock is et38) and fits perfectly and super flush. No issues
