Advice on Chirping Blower Motor Replacement (Passenger Footwell)
Greetings! The blower motor which is under the glovebox in the passenger foot well is making the "cricket" chirping sound. After doing some research here and on other sites, it seems that the blower motor is the culprit. I removed the panel under the glovebox and confirmed that the noise was coming from the blower motor.
A replacement motor is about $160 and I've read the dealer cost is $650 and up. I'd like to give it a shot to replace this blower motor on my own!
Before I buy the part and get myself in trouble, I have some questions I'm hoping you guys can help me with:
1) How is the motor attached? I didn't see any screws or fasteners. Do you twist it to take it out?
2) I see two electrical connectors. Is it safe to assume I can just pull these out? Do I need to disconnect the main car battery?
3) On a similar note, it looks like there are two different electrical connections. On the replacement part photo, it only shows one connector. Any insight into why?
4) Overall, any advice you can share would be greatly appreciated! Warnings, encouragement, etc.
GuestFromTampa (05-06-2017)
Received 4,446 Likes
'71 Pinto
OEM blower motor is part 2048200208 see attachment for replacement.
Very cool. As these cars get older, more and more folks will be doing repairs like this. Were you able to take any pictures of the process? Steps call for removing glove box and cover on right side of dash as well as pulling the blower. It would be very good for the community that when these fairly simple jobs are done, that pictures of the process are shared.
dscottsw (08-02-2023)
Total job took about 15 minutes. I ended up disconnecting the main battery before working, just as a precaution.
Lubricating it was the first avenue I researched. I found step by step instructions for this on a thread, but it wasn't for a W212. Glad I didn't go down that route.
I should have taken a photo of the old blower. It was blackened on the inside. Black powder fell out of it. It was toast!
I just replaced a blower motor and a regulator on my E and can confirm that there is no need for glove box removal.
Very easy DIY .
I also somehow placed double order so now I have a brand new regulator and a brand new blower motor for sale
Very easy DIY .
I thought my blower bearings were going bad as well and was ready to replace the blower motor, however, I began to observe some things which led me to think the bearings were ok.
1) The 'chirping' noise would only occur when the fan speed was set to 3 (3 bars).
2) It was intermittent, however, I managed to figure out how to make the chirp come and go 'on demand' with some trial and error.
With the fan set to 3 (3 bars showing), if I swerved the car right, the chirping would appear consistently. If I swerved let, no noise would appear.
I grasped the fan from under the glovebox while I was at the footwell. Applying pressure a certain way caused the noise to appear, others not so.
It seems that the clearance is marginal somewhere and causing the rotating fan rub.
I'll be taking the fan down this weekend and see what exactly is causing the noise.
On another note, when looking at konigstiger's pdf, I noticed a difference to my setup.
On Step 6, release shackle, I have a plastic insert in the track that prevents the shackle from being spun clockwise. The plastic insert has a zip tie which is holding a wiring loom in place.
mhamdan6789 (12-06-2020)
This is a great write up. Thanks for posting. I've been having the same sound coming from the passenger side of my car as well. I described it exactly like a cricket!
I'll be doing this replacement soon!
Update:
The blower is working like new again. Chirping sound is gone !
A few things worth mentioning. I've noticed some members complaining that they can't twist the blower enough to remove it or have other issues taking it off the car. You must disconnect the wiring harnesses before twisting the motor. Having the wiring harness attached limits the amount you can twist the motor.
Once the motor was removed, I noticed the actual motor was suspended in the black outer plastic casing. I removed the 2 Torx screws (green arrows) at the bottom of the casing and popped the black shield (green arrow) where the wires come out of downward (with the blower facing upwards).
You'll notice the motor is suspended in rubber within the casing and that the shaft the squirrel cage spins on runs the entire length of the motor exiting the bottom of the motor. I lubed this area and other parts of the shaft and cleaned everything up.
Put it back together again and installed ....... quiet and working like new.
The following 5 users liked this post by - Mover -:
mhamdan6789 (12-06-2020),
Mud (02-06-2019),
shadenfroh (07-23-2017),
The Alchemist (02-04-2019),
thefisch (07-24-2017)
I have a W204, and have started to notice this chirping sound as well, more so when I am breaking. Thanks to -Mover-, I'll pull down the blower motor and see if I can fix the issue before buying a new motor.
Thank you sir.
Thank you sir.
My chirping noise is certainly more pronounced when braking. I'm also curious what part of motor gets lubed to make that irritating noise go away! Some pics would be VERY helpful.
More pronounced when braking - that's really odd that the blower motor could be affected by that.
I think it's a design flaw. What appears to happen is that there is some movement in center shaft, causing fan blades to touch outer case depending depending on direction and inertia of travel, which gets exacerbated by braking and uneven centrifugal force.
Here are some before/after pictures. You can see how dirty it was - it is supposed to be white! I used compressed air, a vacuum cleaner, an old toothbrush, a whole tub of cotton buds, and some 'Dettol' cleaning spray, just as a water-like solution really. I'd recommend doing this part outside or wearing a mask because the amount of 'dust' (that goes into your lungs with it you realising) is insane! It took quite a while to clean it up (hard to get into the edges) as the stuff is 'caked' on and not just loose powder. I made a real mess of my kitchen floor.
Oiling is unintuitive and difficult. You will feel like you're not really doing anything. But you need to put oil (I used 3 in 1 oil) on the top and bottom of the shaft, and let it drip down as you spin the motor. It will really feel like nothing is happening, but enough will be going in - and combined with getting all the crap and dust out of there, it should be quiet. Mine has been quiet for one month now.
So yeah, once all the dust is out, prop up the motor and leave it alone for a bit while the oil drips down the shaft. Turn it upside down and do the same. Spin it so that the oil can get into the bearings. Good luck!
The following 2 users liked this post by TeddyRuxpin:
dscottsw (08-02-2023),
Stuttgarten (02-11-2019)
I have the exact same problem on my w212. The sound gets louder when accelerating or braking. The sound goes away when I manually set the fan speed to 1 sometimes 2. I'm glad this is easily fixable.. Thanks for the write up!
