Tensioner Rattle C32
Old 02-22-2017, 02:27 PM
ts82011's Avatar
c32 amg
Hey guys,
I have a major rattle coming from the tensioner area. The rattle becomes more rapid when in gear but evens out around 1300RPM. The problem started after I installed the Eurocharged 61mm pulley a year ago. I thought maybe the belt was slipping do to the smaller size of the pulley causing the tensioner to slap so I purchased a smaller belt and PSK kit from Needswings. Well the problem still isn't resolved after installing those. Your thoughts would be greatly appreciated.
Also, the tensioner is new genuine Mercedes and all the pulleys have been replaced except for the power steering pulley.
Old 02-22-2017, 06:07 PM
macbryanie's Avatar
Porsche 2004 911
The 61mm pulleys are faulty - EC doesnt make them or sell them anymore. Mine completely sheared in half. The rattle could be from the rivets going loose (slapping the plate to the pulley) which was one of the other problems with the 65mm pulley that I had.
Old 02-22-2017, 07:09 PM
Morphh's Avatar
C32 amg
Make sure ur tensioner is not maxed out cause of ur belt length to long, that's what happend to me and the tensioner should be in middle of its range
Old 02-23-2017, 02:34 AM
ts82011's Avatar
c32 amg
I installed the pulley with the same gap as oem and to the this date it checks out the same as when I first installed it
Old 02-23-2017, 02:36 AM
ts82011's Avatar
c32 amg
I purchased the smaller belt from needswings. It could still be maxed out though I don't know how to tell if it is or not. how did you fix yours?
Old 02-23-2017, 04:18 PM
macbryanie's Avatar
Porsche 2004 911
Just putting it our there to be careful please,
It has nothing to do with the adjustment of shims or gap, I am not the only one that had a disaster in the engine bay (are threads on it) - I was on the first batch of that pulley (61mm rivets went) and then received the second version (replacement) and then after that one tore in half - received a 65mm in replacement. (65mm was what I originally had before the 61mm) The 62mm Karmann pulley is the one that has been built well (steel) not aluminium but they are hard to come by. (I think Rudy made a 62mm which was a good one also)
Old 03-04-2017, 11:14 PM
purplecat001's Avatar
2004 C32 AMG
Hey guys,
I have a major rattle coming from the tensioner area. The rattle becomes more rapid when in gear but evens out around 1300RPM. ...
ts82011 -> Did you figure this out? I have the exact same symptomatic noise.
Old 05-22-2017, 10:05 PM
ts82011's Avatar
c32 amg
No I have had this problem for a whilenow. Replaced quite a few parts and still haven't pin pointed the cause. Do you also have the 61mm?
Old 05-24-2017, 06:12 PM
Morphh's Avatar
C32 amg
Do u have pulley saver kit,
Old 05-25-2017, 04:16 AM
ts82011's Avatar
c32 amg
Yes
