SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Oil Change Questions
Old 02-14-2007, 10:51 PM
2mbusa's Avatar
1999 Mercedes Benz SL500 & 2009 E350 4Matic Wagon
Question Oil Change Questions
Now that the warrenty has run out on my 1999 SL500 I don't feel the need to spend in excess of $250 for an oil change.
That said, how hard is it to change the oil?
Is is true that the filter is not a "spin-on" but rather that it has a paper carterage?
As I live in a small town there are not a lot of choices for parts stores and the local CarQuest store had two filters available. One was their house brand for about $14.00 and the other was what they called an OEM brand made in Germany by Henqst for about $10 (an E11H D50 filter). As I remember the dealership (stealership) charged me in excess of $35 for a filter, however, I don't know if it was a Mercedes brand on something else?
Any constructive advice would be greatly appreciated.
Last edited by 2mbusa; 02-14-2007 at 10:54 PM. Reason: To ad price for second filter
Old 02-14-2007, 11:06 PM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
It very easy to change the oil yourself......... the filter is a paper carterage look something like this picture........ always buy OEM brand that made in Germany.......
good luck........
Old 02-15-2007, 09:08 AM
rellik's Avatar
mercedes
this is a good place to buy your filters online:
http://catalog.mercedesshop.com/
id spring the extra little bit to get the fleece filters
i cant believe the stealership is charging you 35 dollars!
Old 02-15-2007, 11:06 AM
reddog's Avatar
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
MB oil filters
I bought extra MB oil filters 2 years ago at the MB dealer for my 1999 SL500:
part #000-180-26-09 $21.28 each.
Old 02-15-2007, 12:09 PM
HLG600's Avatar
R230 SL63 | W220 S55
If you're changing your oil, try out AMSOIL European Formula 5W-40.
Old 02-18-2007, 02:01 AM
carsfastfredi's Avatar
1999 500sl,1991 500sl,1964 T-bird convertible roadster,1964 t-bird convertible,1999 Harley roadking,
1999 500sl oil change
just finished changing oil on my 1999 500sl for first time. unscrew drain plug on oil pan located on passenger side of pan. (13mm) unscrew black plastic cap on oil filter housing(its located next to power steering reservoir. lift off cap filter will come with it. install four new "O" rings reinstall filter add oil "presto wammo" your done. you can get good quality oil filters for $10.00 at www.autopartswarehouse.com good luck
Quick Reply: SL/R129: Oil Change Questions
