SL/R129: 1992 SL500 battery problem
The check battery light was on again even though I have just changed a new battery 2 weeks ago , I asked somebody to check it and he said it was not the problem of the dynamo, can anyone help me?
'87 560SL Sold, '99 SL500 For Keeps
Several things I'd look at...
o Alternator output voltage-if below 12v, pull and replace the voltage regulator/brushes(Bosch OEM buy online for $35, easy DIY) Retest voltage output
o If alternator checks out ok when you first test voltage output, the next thing I'd do is, with the ignition key OFF, and a voltmeter, start pulling fuses one-at-a-time and check voltage...it should read 0. If you get a voltage reading, then you have an open loop current draw on the battery. Replace the fuse with a known good one. Check all the fuses as you can have more than 1 bad one. Good hunting-
