SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: SL500 interior light & power seat problem
Old 09-08-2004, 02:07 AM
rkubara's Avatar
Question SL500 interior light & power seat problem
My 4 interior lights come on when the passenger door is opened, but do not when the driver door opens & it is not the door switch. I was working on the drivers door and shorted the door lamp when inserting it. No blown fuses under the hood or in trunk. Also, the mirror/dome light does not come on with either door when the switch is in the correct position & the overhead switch has been replaced. This is an old problem.
Furthermore, the power seats no longer work when the drivers door is open, only when the key is ion place or when the passenger door is open. The problems are related.
Must be a damaged PCB or relay but 4 local Mercedes dealers will not tell me what part is damaged, they tell me to bring the car in. It was suggested to me that the main light relay box in the fuse box is the problem, it was replaced and did not make a difference. If I can get the elctrical diagrams I could find the PC or replay that is at fault!
Can anyone tell me what component is damaged and where it is?
Wife is annoyed and wants the interior lights and power seat working again!
Old 09-08-2004, 08:40 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Have you checked the door switch? It is located on the A pillar just below the top door hinge. The switch is activated when the door is not pressing on it when open. If it has become dirty or jammed it cannot fully extend to make contact. This would be consistent with what you describe.
- FD
Old 09-08-2004, 11:23 PM
rkubara's Avatar
- FD
I have checked the door switch. I used a meter, swapped it with the passenger one, connected the two wires without the switch and even supplied a ground to the wires just in case. It is not the switch.
It must be a relay that the door switch provides power to. If someone has electical diagrams and can tell me were the wire from the door switch goes, brown with a grey stripe and red bands.
I now realize my seat belt buzzer & light does not activate when I take it off while driving. Not sure if this is related.
Old 09-09-2004, 09:33 PM
Floobydust's Avatar
I have schematics for the R129 series on DVD ROM. I'll see if I can look it up this weekend (the search engine for the DVD ROM is terrible and the details for all years are not always there). I'll post what I find.
-FD
Old 09-13-2010, 05:43 PM
Harley03joe's Avatar
2005 S 500
Post
I Know This Is Very Old Post But Did You Get Your INT Lights Working ?
If So What Was Wrong ??
Harley03joe
Old 10-10-2014, 10:49 PM
perverso968's Avatar
R129.066 1990
Unhappy The same light problem
i read forum post but not have a valid answer because have the same problem with interior light when open passeger door its come on but when open driver door nothing do..? i check the door suitch and same ok. it no have corrent in any wire, all occours after lamp change on pedal and it make a short circuit in the socket because it is broken, after leave an replace the broken lamp socket it not come on never but at passager door open it come on and all other lights to. i check all fuse on fuse box on motor side and trunck side but all its ok. when i active the passager door suitch i ear a tick of a relay and can't locate it...? maybe is a fault relay or another fuse missed in some hide side...? please can help me to locate fault...?
Old 10-10-2014, 10:51 PM
R129.066 1990
sorry i have a 1990 SL500 R129 California
Old 10-11-2014, 12:46 PM
2005 S 500
Smile Your Int Light Probles Is
Your Problem Is The Relay Behind The Pass Side Air Bag, Its On The Plemem Plastic Case In A Clip I Beleave Its Part # 012 545 68 32
Here Are A Few Pictures
Harley03joe
Old 04-05-2016, 03:05 PM
Dustin Bly's Avatar
Mercedes SL 500; 1999
Follow up, did recommended relay part # 012 545 68 32 fix dome light problem ?
-FD
Please advise if part number reference above solved the problem of dome light not working when one or both doors are opened. Also, the floor lights and door lights do work with one or both doors opened. The reading domes lights do work in all positions.
Thanks,
Dustin
Old 07-05-2023, 03:48 PM
KTD_SL500's Avatar
1992 SL 500
Has anyone solved this issue? I have exactly the same symptoms.
BUT there is no N2/4 Relay behind my passenger airbag. (1992 - 500SL)
I believe I hear a relay under the drivers seat that switches on/off when closing the passenger door.
Quick Reply: SL/R129: SL500 interior light & power seat problem
