SL/R230: Problems shifting from Park
Old 12-04-2008, 12:01 PM
mig1980's Avatar
2003 SL55, 2006 CLK500, 1998 Vette
Good day everyone. Just recently (within the last week or so) I started noticing the shifter sort of getting stuck and me having to force it out of Park into reverse or anything else. Any ideas what could be happening here? I don't drive the car hard and am always very careful. It seems like the shifter gate has an issue or maybe the transimission. Once out of Park all gears shift perfectly and I have no problems aside form that.
Old 12-04-2008, 02:42 PM
BACK2DTM's Avatar
03 SL500
I got mine repaired under warranty. Get it fixed before you get stucked somewhere!
Old 12-04-2008, 04:44 PM
mig1980's Avatar
Do you know what it is? I don't have warranty.
Old 12-04-2008, 07:23 PM
BACK2DTM's Avatar
03 SL500
This is what is on the invoice:
Performed function test and verified shifter to be jammed. Unable to shift out of park. Shifter mechanism stuck R&R center console and replaced shifter.
part# replaced:
230-267-49-24 floor shift
230-267-00-17 rod
000-994-43-60 lock
hope this helps
Old 12-04-2008, 07:46 PM
mig1980's Avatar
Thank you very much for the information. Much appreciated.
part# replaced:
230-267-00-17 rod
000-994-43-60 lock
hope this helps
Old 12-04-2008, 09:07 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
I did get mine replaced. cost $600 bucks to replace it by the dealer parts and labor .
Old 12-04-2008, 10:46 PM
BACK2DTM's Avatar
03 SL500
Happy motoring
Old 12-05-2008, 12:10 AM
mig1980's Avatar
I think I am going to pickup extended warranty because I also am having an issue with the trunk and the self closing of it. I have to force the trunk to close all the way.
Happy motoring
Old 02-03-2009, 05:29 AM
monoglobal's Avatar
2005 S500
Repair Solution
I have the plastic part in stock and I can ship worldwide. Log on to www.monoglobal.com.au to view and order the part.
Internal plastic lever is there to prevent children from inadvertedly moving the gearstick lever out of Park. Removing the lever may cause your car to roll away down a hill with your kids inside.
Choose from original plastic or high strength aluminum. Repairs can be done by any reputable MBZ shop in about an hour or two. No need for recoding with Star Diagnosis.
Old 02-03-2009, 12:04 PM
mig1980's Avatar
The dealer had to replace the whole shifter and now it is working perfectly.
Old 03-28-2015, 03:16 PM
madspoon's Avatar
2003 SL500
Shifter replacement
As this forum is a few years old I wanted to add my 2c in here.
Our shifter started getting stuck a couple of weeks ago and now it won't move at all. The mechanic is going to install a used shifter (part no 2302674924) at a cost of approx $450 for part and $200-$300 labour.
The part from the Mercedes dealer was going to be $966 for a new one plus labour.
Let me just tell you that this 2003 SL500 has been an absolute nightmare and I will never buy one of these cars again, Since April 2013 when we bought it with 39k miles on it the following repairs have been done:
- ABC pump had to be replaced
- A/C stopped working, couldn't find leak with dye, twice
- cooling fan had to be replaced
- fuel cap had to be replaced
- ABC pressure hose had to be replaced
- Now the shifter is being replaced and the alternator too
Quick Reply: SL/R230: Problems shifting from Park
