SL/R230: keyless go button on handle
Old 02-02-2015, 09:12 PM
randsny's Avatar
2021 GLE450
I purchased a used 2007 SL550 that had the keyless go entry system and it is missing the small black button. Does anyone know if you can replace the button without replacing the whole handle? Or maybe you know who makes these handles for Mercedes. Seem a waste to buy the whole handle.
Old 02-03-2015, 07:19 PM
randsny's Avatar
2021 GLE450
Contacted Mercedes
I just sent an email to Mercedes to see if they can help me locate the rubber switch. I will let everyone know what I find out.
Attached Thumbnails keyless go button on handle-door-handle-switch-2.jpg   keyless go button on handle-door-handle-switch.jpg
Old 05-17-2015, 10:40 PM
randsny's Avatar
2021 GLE450
Fixed the door handle button
I was not able to find a direct replacement of my keyless go door handle button, so i decided to make one. I cut a small piece of rubber that our fit in the orginal opening and then used black Marine silicon sealant. while this does not look perfect it does seal the opening and the locking button does work very well. if you are having trouble with your button you may wan to give this a try.
Old 11-28-2017, 03:19 PM
Shmatko22's Avatar
C300
There is a solution for this repair!
For anyone out there that is still looking into this:
A company called IE Works sells just the replacement covers.
Quick Reply: SL/R230: keyless go button on handle
