SL/R230: Sat Nav Problem
Sat Nav Problem
Hi Guys,
2005 350SL 43000Mls
While out driving yesterday my sat - nav packed up, display saying Navigation not Available. I tried to eject the DVD from the unit in the boot (or should I say trunk) but it didn't come out.
I presume that its this that's at fault and so my question is can they be repaired or is it a new unit? Anyone else had the same issue?
By the way, after 9 years of ownership this is the first thing to go wrong so the car's not been too bad.
Thanks in advance,
cashwowud
2005 350SL 43000Mls
Thanks in advance,
cashwowud
Navigation Out!
Same problem with my Nav, it says not available, does not eject DVD and when searching thru the menues found Navigation "off" but no way to turn it "on".
Hi - I eventually pulled my unit out and sent it here;
www.headunit-repair.co.uk
Cost was about £175.00 (not dollars)
Excellent service from a guy called Gabor.
Good luck
cashwowud
Good luck
cashwowud
if it is a 5 disc changer tap on the magazine some ad see if it will pop out. my '03 SL has a 5 disc magazine and it can be flakey but always starts up again with a little help
Sat Nav Problem
My Navigation is on a separate DVD player located in the trunk and displayed on the Center Console, integrated with the audio, Sat Radio, in dash DVD and 6 CD Changer behind the driver seat. I've being able to eject it and clean it but still doesn't work.
Fumbling with the steering wheel controls it shows "NAV OFF" but don't know how or if can be turned "ON".
Regular radio, Sat Radio, in-dash DVD & CD Changer all work but not the NAV.
Anyone can help? 😟
Anyone can help? 😟
