SL/R230: Stall out on acceleration
Old 09-18-2016, 07:37 PM
rtd
rtd's Avatar
I have a 2004 SL 500 and it runs really well. However, If I accelerate hard from a stop, it accelerates at first and then makes a hard bump like and stops taking gas. I let off on the gas and it picks up and runs. I can ease it up to about 20 mph and get on it hard and it runs great. It is almost like something is cutting the engine out on hard acceleration. Anyone have any ideas what to look for? Thanks
Old 09-18-2016, 09:06 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
It could be a fuel pump issue, or it could be related the throttle. You could try the throttle resync:
1. Make sure everything in the car is turned off and closed.
2. Turn the key to position 2 so all the dash lights are illuminated.
3. Press the accelerator fully to the floor, depressing the "kick-down" button.
4. Hold the pedal for 5 seconds and continue to hold it down.
5. Turn the ignition switch back one click to position 1.
6. Release the accelerator pedal, but leave the key in position 1.
7. Sit quietly and wait for about two minutes - do NOT open or turn anything on.
8. Listen for a "click" or "ping" noise form the dash.
9. Start the engine and drive the car for at least five minutes.
Old 09-18-2016, 09:53 PM
rtd
rtd's Avatar
I will give it a try tomorrow. Thanks
Old 09-19-2016, 11:01 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
Switch off your EPS
to me seems like your ESP is cutting the ignition.. try switch off the ESP ,and try drive hard again..
Old 09-19-2016, 10:20 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Good catch - ESP will intervene and cut fuel when it detects wheel spin. My SL is not very intrusive, but my CLK was awful unless the tires were brand new. Anytime I wanted to jump out in traffic, I had to disable ESP.
Old 09-20-2016, 06:06 PM
and how did it go ?
did you try ? how did it go ?
Old 09-21-2016, 08:03 PM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
Your cats might be plugged.
Old 09-21-2016, 08:58 PM
rtd
rtd's Avatar
Tried both of these suggestions and it did not change. This just happens when I press the accelerator hard from a stop. If I am rolling and gradually apply gas, it will run good and fast.
Old 09-24-2016, 08:26 AM
JohanSL's Avatar
2006 ML320Cdi Off Road Package; 2010 E500 Cab
Its hard to say without any codes, get yourself a OBDII reader, it will pay for itself very quickly.
My 04 had a similar problem, it came back to life after resetting it by tuning of the ignition, open and close the driver door and restart the engine.
Mine turned out to be the electronic accelerator pedal.
Good luck.
Old 08-17-2021, 02:58 PM
TheBenzOrNothin's Avatar
W216 CL550 2008
Hi, were you able to fix the issue and how i have the same problem on a CL 550 2008 W216.
Thank you
Old 08-17-2021, 06:40 PM
Ohmann's Avatar
2003 SL500 1991 190E 2.3 2011 ML350 1998 SL500
Stalled acceleration
I had this problem two years ago. I replaced the mass air flow sensor. Viola
2003 130k miles
Quick Reply: SL/R230: Stall out on acceleration
