SL/R230: 2004 SL 600 Service B Reset
Old 12-13-2016, 09:03 AM
Dutchman647's Avatar
2004 MB 600 SL, 1967 Corvette Roadster, 2014 BMW 640i and 2016 Corvette Z06
Hi, Guys. I have 2004 SL600 with the Service B indicator which I would like to clear. Anyone know the procedure to accomplish this reset? I have made numerous attempts, but none will work.
Thanks.
Old 12-13-2016, 12:30 PM
moretech's Avatar
2003 sl 500
Not sure if it's the same as on my 2003 sl 500 but when it shows it is "due now" in the display just hit reset till it says something like "do you want to reset" and then hit reset again and hold it down a long time and it should "reset". It was sort of easy on my model.
moretech
Old 12-14-2016, 10:29 AM
moretech
Thanks, I have tried that option a number of times and it doesn't come up with a choice to reset. The SL600 must have a unique way to reset the display. It would be nice if MB made it simple.
Old 12-14-2016, 10:22 PM
MBworld Guru
Rudeney's Avatar
Received 1,004 Likes on 872 Posts
NO LONGER ACTIVE
See if any of this helps:
https://mbworld.org/forums/clk-class...st-models.html
Old 12-15-2016, 10:42 AM
2004 SL600 Service B Reset
Thanks, Rudeney. I got it cleared. I had to use the "Model 230
(SL-CLASS from MY2008 to Present" procedure, but it worked
just fine. Your help is much appreciated. Cheers
Old 12-15-2016, 10:06 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Glad to help! But Glen on the W209 forum is the guy who put all that together.
Old 01-22-2017, 01:35 PM
DonMarco's Avatar
2006 SL500
Thanks! I have a 2006 SL500 and had to use the MY 2008-up procedure, too. But it worked!
Quick Reply: SL/R230: 2004 SL 600 Service B Reset
