SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 85 380sl odometer repair
Old 06-12-2013, 04:51 PM
fred1985's Avatar
1985 380sl and 04 clk55 amg
Unhappy 85 380sl odometer repair
My odometer and trip log has quit working. Noticed it at last fill up. Have it removed and all gears are in good shape. My buddy feels it is a diode above the 4 wire connector. Does this make sense? I have looked through parts sites for such an item and all I get is gear replacement kits.
Old 06-12-2013, 06:41 PM
fred1985's Avatar
correction
We now believe this is not a diode but a 100 ma/250v fuse. It is blown. Can it be bought without buying the whole speedometer assembly?
Old 06-17-2014, 12:22 AM
03see2thirtyk's Avatar
03 w203
My father in law has an 84 with the same issue. Speedo works fine but odometers not functioning.
I tried the reset while driving and it reset but still not working. It seems to click at times.
Old 07-03-2014, 12:57 AM
TheObject's Avatar
1985 380SL
Nobby has a great write up on broken odometers.
http://www.benzworld.org/forums/r-c1...-tutorial.html
I had the same thing happen on my 380 a couple of days ago. Waiting for the new gears to come in.
Old 07-03-2014, 01:34 PM
03 w203
That write up was great....
The gear I ordered came in yesterday. Already installed on cluster and just finding time to put cluster back into car. The odometer gear that was broken was the one that I didn't have to count thankfully.
Old 10-05-2020, 04:38 PM
Adam Greenwade's Avatar
1982 380sl
Fred, did you ever find a solution? I've replaced my gears and still no action on my odometer or trip meter. I've eyed the same tiny fuse...wonder if you ever figured it out? Thanks.
Quick Reply: SL/R107: 85 380sl odometer repair
